Are your headlights too BRIGHT.
Discussion in 'Lighting' started by mag326, Feb 12, 2019.
  1. Feb 12, 2019 at 2:14 PM
    mag326
    mag326 [OP] New Member
    2011 Tundra Crewmax Rock Warrior
    I drive 10 minutes to work, and get flashed like 3 times every morning. I really get there attention when I flash them back. Truck came with SYLVANIA 9006 Basic Halogen Headlight Bulb.
  2. Feb 12, 2019 at 2:16 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe they’re pointed up too high. Try adjusting them down with a little knob on the left if your truck has it. If anything our lights aren’t bright enough for me.
  3. Feb 12, 2019 at 2:18 PM
    I slapped those Sylvania ZXE Gold HL n fogs they bright, but I will be buying '19 PRO LED lights
  4. Feb 12, 2019 at 2:22 PM
    15whtrd
    15whtrd Mr. Blonde
    Every time I’ve upgraded to just a brighter version of a stock headlight I don’t get much life span out of them. Did yours last you?
    Also when you change the lightbulbs do you take the front grill off and pull the whole headlight out to change it or do you come in through the fender liner?
    By the way, that cheap fabric rubber they put behind the headlights is trash! Mine is already ripped and I never touched it. Almost like the wind blew it out.
  5. Feb 12, 2019 at 2:26 PM
    mag326
    I have dial on 4. It looked like the lights point towards ground. I Think 0 is level. Thanks
    15whtrd likes this.
  6. Feb 12, 2019 at 2:30 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s probably just because you are big and tall in your truck and your headlights are naturally going to be pointed towards the eyes of a low commuter car.
    NewImprovedRon likes this.
  7. Feb 12, 2019 at 2:31 PM
    mag326
    I purchased truck last September not sure on life span of lights. They where in truck when I got it. I just reached in popped wire harness off has one clip, then just quarter turn pops right out. It is really tight, but works.
    15whtrd likes this.
  8. Feb 12, 2019 at 2:32 PM
    They bright, bought them just recently, I take whole light out, I know it's a hassle
    15whtrd[QUOTED] likes this.
  9. Feb 12, 2019 at 2:32 PM
    boloson
    boloson New Member
    I have the retro 18 OEM lights & I get flashed. Pointed down some more & no more flash
  10. Feb 12, 2019 at 2:36 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Running with your fogs on?
  11. Feb 12, 2019 at 3:14 PM
    mag326
    No fog lights. when I do run them I turn them off, with traffic. I thought about getting h11 I think that is stock.
