11” lift and 40s!!!
Discussion in 'General Tundra Discussion' started by SullyMoto19, Feb 12, 2019.
  1. Feb 12, 2019 at 1:29 PM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    I'll be getting larger tires soon, so want to prevent rub on the actual body of the truck. I have a 14" wide wheel (-76 offset) and the tires will be 15.5" wide. Currently at 11" of total lift. I'm speculating that I may run into this problem if I don't address first.
    Has anyone "rolled"(?) this piece before? I'm looking to get an extra 1-1.5" of clearance if possible. I'm sure some offroad/trail guys have done something similar.
    The picture shows the part I'm talking about circled in red.
    Let me know if you have any recommendations, TIA!
    BestGen, Erichudgins and Berdine like this.
  2. Feb 12, 2019 at 1:45 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  3. Feb 12, 2019 at 1:49 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    How about some glass fenders?
  4. Feb 12, 2019 at 1:58 PM
    SullyMoto19
    Tyler
    Houston, Texas
    well ive always liked the look, but I feel like it be way to much of a hassle to get them painted and all that. my buddy did a front end conversion on his 07 and it looks like a Baja style 3rd gen. but just seems like it may be more pain
    joonbug[QUOTED] likes this.
  5. Feb 12, 2019 at 2:08 PM
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    You’ll probably need a body shop to trim and fold that or go to glass fenders like Joon said. I don’t think there’s a good way to DIY a roll that deep there. What you may also run into is the firewall. If you think you have to remove that much fender, the firewall isn’t far behind. Have you already chopped the body mount? We whacked the piss out of ours and flattened the pinch welds to squeeze 37s under a 2” lift.
    Also, glass would look fuckin killer on your truck. Here’s my wife’s.
  6. Feb 12, 2019 at 2:14 PM
    Throwwire
    Throwwire New Member
    Gerry
    Humboldt county
    08 ext cab,16 platinum crew
    08 leveled 35s fab four bumpers light bars 16 leveled
    I just had to trim my back part you you circled,trimmed off the plastic and pushed the pinch weld back with a hammer.gained that 3/4 inch I needed, sounds like you might need more trimming rolling then I did though
    BestGen and SullyMoto19[OP] like this.
  7. Feb 12, 2019 at 2:39 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    It's called the 'pinch weld mod' and it's been popular with the early 4Runner crowd forever. Don't cut it cause it's holding two panels together. It's as simple a mod as it gets. Get your BFH and pound it flat. Done. :thumbsup:
  8. Feb 12, 2019 at 2:52 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    with those icon ucas..you have much more adjustment than most.. id take it to the alignment shop and have them push the lower control arms forward and adjust it out with the uppers. kevin can give you the exact numbers.. he gave me mine.
    KevinK likes this.
  9. Feb 12, 2019 at 2:53 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    kevin im still amazed you can run the stock front bumper lol
    KevinK[QUOTED] likes this.
  10. Feb 12, 2019 at 2:55 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Actually I think that’s @Spvrtan old pic lol I snagged it from the internet lol
    KevinK and Erichudgins[QUOTED] like this.
  11. Feb 12, 2019 at 2:56 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    ahhh ok lol then it may be a little more complicated lol.
  12. Feb 12, 2019 at 2:57 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Does she have front and rear?
  13. Feb 12, 2019 at 2:58 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I just took these pics.. this is full crank, and the BMC will be done before new tires. Obviously the 37s have had better days, that’s why they’re being replaced lol but I’ll see if I can think of something.. I don’t want any paint damage, so cutting might be a no-go
  14. Feb 12, 2019 at 3:00 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    I think your issue will be more with the body mount... but given your particular geometry that's an easy fix for you looks like
    SullyMoto19[OP] likes this.
  15. Feb 12, 2019 at 3:03 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I’m gonna get the BMC done.. hopefully this weekend or next
    Erichudgins[QUOTED] likes this.
  16. Feb 12, 2019 at 3:04 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    yea that one corner looks like is where it will most likely need to be chopped ...but I think you just be close on the actual fender
  17. Feb 12, 2019 at 8:34 PM
    KevinK
    Tundras to Sedona
    It got trimmed too. ;) but it still matches the lines, so you can’t really tell.
    I was gonna ask if that was his from when he had the white methods.
    Just front glass. Our rear doesn’t need it.
    I’m a little confused on the difference in tire size from old to new. Up above you said “ Ihave a 14" wide wheel (-76 offset) and the tires will be 15.5" wide.”
    What size tire are we looking at in the picture where you show how close it is? Are you using the same rims?
  18. Feb 13, 2019 at 6:48 AM
    SullyMoto19
    Tyler
    Houston, Texas
    So currently, my set up is an 8” readylift with a 3” body lift.. 11” total lift.. I have 22x14 wheels wrapped in 37x13.5s.. I will be going at least to a 38x15.5 tire, but hoping to stuff 40x15.5s if at all possible lol
    KevinK[QUOTED] and Throwwire like this.
  19. Feb 13, 2019 at 7:25 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I'm thinking about the sso slimline hidden winch option... but wasnt for sure if the stock bumper would mesh with the 7s..you running the 0 caster setup you sent to me?
  20. Feb 14, 2019 at 11:23 AM
    KevinK
    Tundras to Sedona
    That is for sure an aggressive size difference. I’m gonna have to phone a friend and tag @Spvrtan here to see how he manages the 40s. I assume the massive difference between you guys’ setups is the widt and offset.
    Based on the clearance you showed earlier, I imagine the 38 could probably fit. A 40 is going to be 1.5” taller and 1” wider. A little trigonometry suggests you’re gonna be deep into the firewall at your current alignment and offset.
    Try this: turn the wheel to the point where the tire is closest to whatever it’s gonna hit. Measure that distance and see if you can cut it enough to gain a 2” gap from your current tire (trying to account for the missing tread on existing tire).
    The SSO looks best to me so far. I think Victory 4x4 is putting a similar solution on their roadmap.
    Yeah we’re on 0 offset now with the 37s. It’s actually about a -5 when the beadlocks get factored in. Just have to trim that bumper a little in a line that keeps it looking stockish.
    The only issue now is I trimmed where the bottom of the bumper cap used to connect to the supporting structure and it flops around a touch off road. I just need to drill a new hole through the support and bumper and slap a bolt through it to hold it still. If you look at the tire-side of the bumper below the fog light mount you’ll see where the dot light surround bolts to the bumper cap. That’s what I undid.
  21. Feb 14, 2019 at 12:17 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Biggest difference is going to be offset. Currently about 60% of the wheel is outside of the wheel well.. I'm thinking its going to be possible, but im gonna have to brainstorm a little on the fender. Appreciate the feed back
  22. Feb 14, 2019 at 12:52 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    Okay.. nice.. that looks clean man.. had you not shown me this I'd never have Been able to point it out.. well done sir. And your on 13.5s too.. I'm just on 12.5s so I have a little more room to work lol
  23. Mar 6, 2019 at 9:50 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Update: 40x15.5 fit!! Slight rub at full crank and in reverse. Couple adjustments and we’ll be clean as a whistle..
    BTW: Whatta HUGE difference there is between 40s and 37s
  24. Mar 6, 2019 at 10:05 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Bad ass!!:mudding:
  25. Mar 7, 2019 at 9:12 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Thanks man!!
    GiantsFanDan[QUOTED] likes this.
  26. Mar 7, 2019 at 2:24 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    What wheels are those?
  27. Mar 7, 2019 at 2:35 PM
    Extremely Badd Assss!
  28. Mar 7, 2019 at 3:55 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Thanks brother
  29. Mar 7, 2019 at 4:00 PM
    Having the best color doesn't hurt either Tyler!
