  1. Sep 2, 2016 at 6:59 PM
    #1531
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Pull harder!
  2. Sep 2, 2016 at 7:02 PM
    #1532
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Harder I shall try tomorrow!
  3. Sep 2, 2016 at 7:05 PM
    #1533
    ToyotaTundraMike
    2015 Tundra
    Once you get the top clips out just work your way down one side and then the other. Once they start popping out its pretty easy.
    Krezz[QUOTED] likes this.
  4. Sep 2, 2016 at 7:06 PM
    #1534
    Krezz
    Kevin
    Here was today's projects.
    Got the KO2s on, along with some LED fog lights. Rigid mounting brackets with Speed Demon BlackOps lights.
    Also placed in an LED bed light system. mattgecko from over on TacomaWorld supplied them for me.
  5. Sep 2, 2016 at 7:09 PM
    #1535
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I understand your reluctance to just go crazy on it. I would advise not to pull harder, but instead peel back the top after you have removed the 2 clips and 4 screws and look down behind on either side. The colored body piece that sits just below your headlight has two holes in it that tabs from the grill push into. If you look down behind the grille as you have the front peeled back you will see them. The tabs are notched so that they press up into those holes - I found that if you put your hand inside the front of the grill as close as you can to that tab/notch, and push down with that hand while pulling outward with the other it's very easy to separate the grill. I've had mine off probably 10 times now and was bragging to my wife how I can now strip the headlight assemblies in about 10 minutes.
    Pulling harder will also work, but I feel you run the risk of damaging not only the tabs on the grille, but possibly that painted body moulding as well. Good luck!
  6. Sep 2, 2016 at 7:11 PM
    #1536
    Krezz
    Kevin
    thank you and everyone whos replied. I shall attempt again tomorrow with more gusto and direction. I hope to report back with pictures of the new grille installed!
    SouthBoundSteve likes this.
  7. Sep 3, 2016 at 1:01 PM
    #1537
    ludakrs
    ludakrs New Member
    SW Houston
    2016 TRD PRO
    Some stuff
    Today installed Spyder headlights.
    Have a gap on the driver side at the fender and top of housing, anybody else have issues like this20160903_112815.jpg 20160903_112855.jpg
    rideandfly and SouthBoundSteve like this.
  8. Sep 3, 2016 at 1:26 PM
    #1538
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Added Spyder HID projectors
    Benni, Ancient1, omaguz and 7 others like this.
  9. Sep 3, 2016 at 3:43 PM
    #1539
    Backslider
    Tooele, UT
    I had the same issue. Look inside the hood at the top of the headlight assembly and you will see where it rubs against the body of the vehicle. Remove 2mm of plastic or grind the cross bar a little to resolve.
    ludakrs[QUOTED] and ChucklesToy like this.
  10. Sep 3, 2016 at 7:35 PM
    #1540
    Lighting is great!
    rideandfly likes this.
  11. Sep 3, 2016 at 7:35 PM
    #1541
  12. Sep 3, 2016 at 9:20 PM
    #1542
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Spyders look great, the LED looks really bright. Are those how they come or did you mod them?
  13. Sep 3, 2016 at 9:32 PM
    #1543
    Just did the hid with it and that's it
  14. Sep 3, 2016 at 10:34 PM
    #1544
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Finally, ordered ADS coilovers from Matt at MCM Fab.
  15. Sep 4, 2016 at 8:24 AM
    #1545
    Blankcheese
    Blankcheese New Member
    Johnny
    '16 SR5 DC 4WD
    image.jpg Bought these wheels!! Pics to come after the 3/1 lift and Toyo 285s are also installed, probably in two weeks. Can't wait! RIP pulling into my garage....
  16. Sep 4, 2016 at 4:22 PM
    #1546
    rmarch109
    rmarch109 New Member
    BOBBY
    2016 CREWMAX TUNDRA
    Just changed out all the lights in the interior of the truck
  17. Sep 4, 2016 at 6:03 PM
    #1547
    Waxed/polished the living shit out of it
  18. Sep 4, 2016 at 7:47 PM
    #1548
    PMG
    PMG New Member
    Where fid you get your set from?
    PMG
  19. Sep 5, 2016 at 5:38 AM
    #1549
    allstar617
    allstar617 New Member
    Sy
    Boston,Ma
    2014 sunset bronze 1794
    Thule areoblade roof racks,Full Led conversion, rackarod lockable rod holders,Led bed lights,Lock'er down safe, 42" led light bar.......6112/5160 suspension lift Coachbuilder +3 shackles, shims and bushing set. Toyo open county AT2’s 295/65/20’s on stock black painted wheels..........
    image.jpg image.jpg image.jpg image.jpg image.jpgBefore image.jpgafter image.jpg
    Well not in a day but a weekend project.
    Bilstien 6112/5160
    CB +3 shackles
    Bora 1.25 spacers
    Toyo open country at2's
    295/65/20
    Black platinum wheels
    BR73, MotoTundra, aperezsh and 11 others like this.
  20. Sep 5, 2016 at 8:01 AM
    #1550
    omaguz
    omaguz New Member
    omar
    Puerto Rico
    2015 Magnetic Grey 1794 Tundra Crew Max
    Hey @allstar617 could you tell me about the roof rack you have on your truck???
  21. Sep 5, 2016 at 8:15 AM
    #1551
    Looks like a ski rack, not a roof rack.
  22. Sep 5, 2016 at 8:18 AM
    #1552
    Backslider
    Tooele, UT
    It's a Thule 480, or at least it looks that way. It's a completely removeable rack.
    I have a Rhino Rack installed with tracks. Was about $900 for mine, installed with lifetime warranty.
    driverdog, omaguz and allstar617 like this.
  23. Sep 5, 2016 at 8:24 AM
    #1553
    allstar617
    Sy
    Boston,Ma
    Yea, Thule 60" aero blades with Thule foot pack, and on top I got a Rac A Rod lockable rod holders. Let me know if you any additional info. image.jpgimage.jpg
  24. Sep 5, 2016 at 8:29 AM
    #1554
    Backslider
    Tooele, UT
    Awesome! I've been looking for a roof mountable rod holder - how do you like yours? Pros and cons? Do you ever end up with dead bugs on your reels? This is honestly my biggest worry..
  25. Sep 5, 2016 at 8:51 AM
    #1555
    allstar617
    Sy
    Boston,Ma
    No complaints at all- I highly recommend the Rack A Rod system made by Hal out of NY. No bugs on the reels so far but I do get them on the crossbars. I had them on for the whole season and my main concern was rocks chipping at my reels but that has never happened (knock on wood) and I drive 80 miles round trip to the Cape Cod Canal.
    Backslider[QUOTED] likes this.
  26. Sep 5, 2016 at 9:18 AM
    #1556
    allstar617
    Sy
    Boston,Ma
    All loaded up
    http://www.racarod.comimage.jpg image.jpg
  27. Sep 5, 2016 at 9:30 AM
    #1557
    omaguz
    omaguz New Member
    omar
    Puerto Rico
    Looks great brother, I'll take a look at them. Thanks for the help buddy!!!
  28. Sep 5, 2016 at 9:33 AM
    #1558
    omaguz
    omaguz New Member
    omar
    Puerto Rico
    What is the model for the foot packs???
  29. Sep 5, 2016 at 9:46 AM
    #1559
    Backslider
    Tooele, UT
    You need the 480(any submodel but R are the best) and the fit kit for your year and model of vehicle. You also need bars (58" - 60"), and locks.
    omaguz[QUOTED] likes this.
  30. Sep 5, 2016 at 9:48 AM
    #1560
    Backslider
    Tooele, UT
