  1. Feb 7, 2019 at 5:08 PM
    #3421
    Mnorris1206
    08 tundra
    Thanks ! Some think I should have done something other then white on the spring but I like it so .And its a pavement princes and thats ok. Lol
    ecm209 likes this.
  2. Feb 9, 2019 at 10:09 AM
    #3422
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Part Two: UnderCover Classic for my RCSB
    Another one appeared on Craigslist... $250.00 installed.
    I'll post pictures in my build thread.
    Stormtrooper81 and Mnorris1206 like this.
  3. Feb 9, 2019 at 1:04 PM
    #3423
    sthnrebjr
    sthnrebjr New Member
    Rick
    2007 Tundra SR5 DBL CAB
    Installed OEM style fog lights in my 2007 DBL cab SR5. It was factory wired. I had to replace the turn signal lever with one with the fog light switch. No infomation on the MOD anywhere. Toyota wasn't sure if it would work or not, but I successfully completed installation today and everything works. Fog lights are just as they would have came from the factory.
    CaptSpaulding, ecm209 and Trooper2 like this.
  4. Feb 9, 2019 at 2:20 PM
    #3424
    stewtopia
    stewtopia 4RunningTundra
    Stew (nickname)
    Masshole
    Westin Outlaw front bumper
    Ajak, Poconozoo, NE_WARRIOR and 6 others like this.
  5. Feb 9, 2019 at 3:28 PM
    #3425
    Gtfour43
    Gtfour43 New Member
    Oahu
  6. Feb 9, 2019 at 3:34 PM
    #3426
    ecm209
    ecm209 New Member
    Eddie
    2013 Magnetic Grey Tundra Rock Warrior
    8" FTS lift kit, Lift kit painted Racing Red, 22x12 American Force wheels, 35" Toyo Open Country R/T tires
    Not specifically made for the tundra but for sure compatible with 2 gen tundras.
  7. Feb 9, 2019 at 4:12 PM
    #3427
    kgb4187
    kgb4187 New Member
    Had my cheap rims put on
    51531074_10218559012074406_4626156828399_e0d04d8814cd3456376f1796aebb73171a01a8f4.jpg
    51748954_10218559012554418_8380707880105_7a3989e8ecf67c5c076f12b93e03fd807cfe1bc3.jpg
  8. Feb 9, 2019 at 4:13 PM
    #3428
    Mnorris1206
    08 tundra
    Nice ! Cheep or not looks good.
  9. Feb 9, 2019 at 4:39 PM
    #3429
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Agreed. @kgb4187
    kgb4187 and ecm209 like this.
  10. Feb 9, 2019 at 5:07 PM
    #3430
    kgb4187
    kgb4187 New Member
    Thanks!! I just wanted to make sure I liked that much black before finding a set. I was thinking about having the original SR5 wheels put on when they fix the studs, but I might paint the center caps and leave them until I make up my mind about having them powder coated.
    Mountun Goat likes this.
  11. Feb 10, 2019 at 1:04 PM
    #3431
    Trooper2
    JR
    Houston, TX (Suburban South)
    Oil change today, fresh Mobil 1.
    Finally installed on new Aluminum Canister and Fumoto drain plug.
    Also tried the washer bottle funnel hack, worked great! :thumbsup:
  12. Feb 10, 2019 at 1:17 PM
    #3432
    TheBeast
    TheBeast The Beach
    which Mobil 1 viscosity did you use ?
  13. Feb 10, 2019 at 1:32 PM
    #3433
    Trooper2
    JR
    I believe the Manual says 0W-20 or 5W-20 for 5.7L. I think colder climates should use 0W-20, I am in warmer area, Houston. That being said, for our 07 with 133K miles, I bought 0W-20 but I did use about 2 1/4 Quarts of some unused 5W-20. So by my fuzzy math, I am at 1.5W-20 :thumbsup:
    Prostar 190 likes this.
  14. Feb 10, 2019 at 7:01 PM
    #3434
    Trooper2
    JR
    Also figured out that the plug from the plastic canister needs to be transferred as well to the new Aluminium one, The new one did not come with one, thought odd but maybe didn't need one. Noticed a small oil spot on driveway later, decided to put the plug and O ring on. At least the new spot on drive way is "clean fresh" oil, not the dirty dark kind. LOL
    Prostar 190 and Mnorris1206 like this.
  15. Feb 10, 2019 at 7:05 PM
    #3435
    Mnorris1206
    08 tundra
    Does the fumoto valve seem a good quility ? I worry about getting one and having the valve part its self being bad and leaking but thats just me being a plumber lol
  16. Feb 10, 2019 at 7:13 PM
    #3436
    I like mine and was hesitant for a while also.
    Mnorris1206[QUOTED] and Trooper2 like this.
  17. Feb 10, 2019 at 7:15 PM
    #3437
    Trooper2
    JR
    It does seem like it is built well. It is a rotary valve that has fairly tight clearances, tight but smooth action, if that makes sense. I believe there are some options that include a plug if your that concerned.
  18. Feb 10, 2019 at 7:34 PM
    #3438
    Do you happen to have the part numbers for the canister and valve? Thanks.
  19. Feb 10, 2019 at 8:02 PM
    #3439
    Trooper2
    JR
    Fumoto F-103 with LC-10 Included F-Series Engine Oil Drain Valve From Amazon. The Fumoto website has some different variations for hoses and other options.
    Aluminium filter cap Genuine Toyota 15620-31060 Oil Filter Cap Assembly from Amazon. You have to switch the center pieces, the new one is shorter, easy swap, move plug over as well.
  20. Feb 10, 2019 at 8:05 PM
    #3440
    Awesome.....thank you. I'm tired of snapping tabs on the plastic one.....even with using the cap tool. Has there been any leaks with the drain valve?
    Trooper2[QUOTED] likes this.
  21. Feb 10, 2019 at 8:11 PM
    #3441
    Trooper2
    JR
    Just installed, so not yet. I do not expect any, many seem to use without issue.
    Mnorris1206 likes this.
  22. Feb 11, 2019 at 4:48 AM
    #3442
    Rex Kramer
    Georgia
  23. Feb 11, 2019 at 9:20 AM
    #3443
    mag326
    mag326 New Member
    2011 Tundra Crewmax Rock Warrior
    Firestone ride rite bags, power stop z36 slotted rotors, and padsIMG_20190127_160816681.jpg IMG_20190126_100645759.jpg
    nuclearlemon, Ajak, Jach2008 and 7 others like this.
  24. Feb 11, 2019 at 9:22 AM
    #3444
    Looking good. I really like my Power Stop rotors and pads. I made sure to do the break-in.
  25. Feb 11, 2019 at 9:25 AM
    #3445
    mag326
    mag326 New Member
    Remote start easy install plug and play with Fortin remotes.
  26. Feb 11, 2019 at 9:33 AM
    #3446
    mag326
    mag326 New Member
    I put in a front camera, everyone thinks I'm nuts. I just got first Toyota last year. I have been adding stuff since
  27. Feb 11, 2019 at 11:43 AM
    #3447
    Mnorris1206
    08 tundra
    I'm going to miss my truck for a whole day as my buddy takes it in for an alignment to his workplace tomorrow. I just may miss it after driving this Beast around
  28. Feb 11, 2019 at 12:31 PM
    #3448
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
    I love seeing someone with the exact same truck as me that has more time and money to put into it so ill know exactly what mine could look like. Nice choice on the brakes, i just did mine in December.
  29. Feb 11, 2019 at 1:58 PM
    #3449
    fairclothr1
    fairclothr1 Here and There Member
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    I have a sand mica DC and was thinking about plasti-dipping the wheels to black them out, but wasn't sure if I'd like it. Seeing those steelies on yours, I love it. Already blacked out the grill and badges. Need to do the bumpers down the road.
    Stormtrooper81 likes this.
  30. Feb 11, 2019 at 4:24 PM
    #3450
    TXTundraSC
    TXTundraSC New Member
    College Station, Tx
    2011 Tundra Platinum 4x4 s/c
    Magnuson S/C, trd exhaust, trd rear sway bar, trd front sway bar, toytec 2.5” level, debadged, toyo r/t 305/55r20
    10103FCB-A6E6-48D5-92DF-0C428618EED1.jpg 0A404B63-E01B-4644-BB60-F8EF2AB1AAED.jpg
    Gonna ride around ugly for a few days, but it’ll be worth it when the last of the chrome disappears!!!
