Inner fender for fiberglass
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erichudgins, Aug 5, 2018.
  1. Aug 5, 2018 at 7:26 PM
    Erichudgins
    Erichudgins [OP] New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    For the guys that are running fiberglass. What are you all using for inner fenders?
  2. Aug 5, 2018 at 7:58 PM
    n2deep
    n2deep Pavement Princess
    Nothing - a few have tried to make something but the tires just destroy them.
    dcsleeper408 and Erichudgins[OP] like this.
  3. Aug 8, 2018 at 7:26 AM
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Wondering the same. Any issues with running open liner?
  4. Aug 8, 2018 at 7:29 AM
    trooper669
    trooper669 New Member
    2018 1794 MGM
    TRD front and rear sway bars/ CAI. Recon smoked tail lights. LED Bed Lights. LED grill lights Bilstein 6112 front and 5100 rear. RC 1” rear block. RC lower grill LED bar. Nitto Ridge Grapplers 295x60x20 on Fuel D-251 couplers. SDHQ ABS covers. Rear under seat storage. Body mount rebuild. Color matched mirrors, handles. Raptor step bars.
    Wondering the same
    Erichudgins[OP] likes this.
  5. Aug 8, 2018 at 7:40 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You bastard
  6. Aug 8, 2018 at 7:40 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    @TRON had some liners made
  7. Aug 8, 2018 at 7:43 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    :devil:
  8. Aug 8, 2018 at 7:45 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I actually spoke with him on ig a few days ago and he said he never had any made. Said he looked into it but never followed through. I'm only really concerned about the back side of the headlights.. I am pretty sure I can fit something together nicely once i have everything on and see what I'm working with..
    boardude[QUOTED] likes this.
  9. Aug 8, 2018 at 7:46 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    dcsleeper408, Pudge and so_juanderful like this.
  10. Aug 8, 2018 at 7:48 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I'm logging off now
  11. Aug 8, 2018 at 8:10 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    :jellydance::oldglory:
  12. Aug 8, 2018 at 9:00 AM
    n2deep
    If your LT you will rip them off unless you limit your up-travel. If you MT you should be fine. @osidepunker made a set and they did OK but still ended up tearing them up on bigger hits. We were talking about cutting out the inner fenders and moving them up to create more room but nobody has done it yet because it requires moving a lot of stuff in the engine bay. I live in the desert so don't have any real issues but I don't blast thru water/mud and it rarely rains here. The biggest issue is the Air intake is totally exposed and open but I have yet to get any water into it. I do get rocks in the air box and have to clean my filter more often.
  13. Aug 10, 2018 at 4:38 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    What he said^^
    If you're MT then you can just do some plastic liners and pin them in. I did that twice. But I'm LT and the tires make contact on big hits and rip them off so I gave up.
    Back of headlight don't worry about it. Its a sealed unit
    Exposed intake is only an issue if you do a deep water crossing. But I have done 2' of water a couple times with no problems. You do get more dirt and rocks in there like @n2deep said, but just keep your air box clean. I change my filter and vacuum it out every couple trips
  14. Aug 10, 2018 at 5:46 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    in for pictures of fiberglass fenders! been thinking they're a good option for my beat up corners...
  15. Aug 10, 2018 at 5:53 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I went ahead and purchased the pump relocation kit. Just for the added insurance. And yea I'll be completely MT so I may just do some massaging of the liners and refasten them. I'll play with it. I'm creative so I can figure something out surely. I'll keep everyone posted. Gonna be a few more weeks before I even fool with fitting them. Got a couple trips planned and I don't want to be playing trial and error in the middle of the woods..
  16. Feb 10, 2019 at 7:39 PM
    TXTundra2722
    2015 Black Tundra
    Any update to this or was this a really, really long trip?
  17. Feb 11, 2019 at 7:46 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Lol update is fenders are off the truck and sold. Went back to stock.
  18. Feb 11, 2019 at 7:57 AM
    TXTundra2722
    2015 Black Tundra
    Haha! What happened? I've been considering glass fenders or pro comp fenders as a last resort.
  19. Feb 11, 2019 at 9:07 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    No liner = eventually damaging those nanny air pumps especially if you mud, lol.
