LED headlight Conversion Recommendations
Discussion in 'Lighting' started by DiegoC, Feb 5, 2019.
  1. Feb 5, 2019 at 5:46 PM
    DiegoC
    DiegoC [OP] New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    Anyone have any recommendations? I currently have the stock lights on my 16 limited
  2. Feb 5, 2019 at 6:05 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    18 leds.
  3. Feb 5, 2019 at 6:14 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Morimoto 2Stroke 2.0 H11 LED Plug N Play
  4. Feb 5, 2019 at 6:15 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    2018-19 OEM full LED headlights with a plug and play harness from @iHacker
    mtTundra, Buildn, Watt maker and 3 others like this.
  5. Feb 5, 2019 at 6:51 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    WHAT EVER YOU DO GET YOUR HARNESS FROM @iHacker he’s got the best one period! Even if it’s cheaper elsewhere save yourself the headache!!
    Buildn likes this.
  6. Feb 5, 2019 at 6:58 PM
    War Machine
    War Machine SSEM # 5 3MW
    X2. Installed my 19 TRD Pro headlights last weekend. His harness made it easy.
    TXRailRoadBandit73, Pudge and Pinay like this.
  7. Feb 5, 2019 at 8:22 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X3, on this one.
  8. Feb 8, 2019 at 7:34 AM
    DiegoC
    Diego
    can anyone show me what their iHacker harness looks like?
  9. Feb 8, 2019 at 7:51 AM
    Buildn
    Medina, Ohio
    This was the set up for my truck. LED’s on high all the time. Ihacker harness’ are truly put together with top quality.
    He only uses Toyota quality connectors.
    Watt maker likes this.
  10. Feb 8, 2019 at 7:53 AM
    DiegoC
    Diego
    So with those I can run any LED?
  11. Feb 8, 2019 at 8:13 AM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    If you have any lighting questions, I can help! :)
  12. Feb 8, 2019 at 8:17 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Those harnesses are for if you swap out your headlight housings to the new LED headlight housings on the newer trucks.
    Are you looking for a complete replacement or just an LED bulb?
    DiegoC[QUOTED][OP] likes this.
  13. Feb 8, 2019 at 8:39 AM
    Buildn
    Medina, Ohio
    Diego,
    Yes, ihacker has vehicle specific set ups for what you want your led headlights to do. He also has instruction on this website as to how to install. Just contact ihacker and he will guide you through the process.
    DiegoC[OP] likes this.
  14. Feb 8, 2019 at 8:42 AM
    DiegoC
    Diego
    I don't really know yet. I'm just starting to look around and honestly i'm willing to spend money if need be. Id rather pay the money and do it right, but if it makes sense to just LED bulbs it doesn't matter to me.
  15. Feb 8, 2019 at 8:53 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    This
  16. Feb 8, 2019 at 10:04 AM
    bdpeelgren
    Round Rock, TX
    If money is no issue then I would go with the 2019 pro LED housings.
    But there are LED bulbs that are a much cheaper option but perform really well.
    I went with just the bulbs and I’m pretty happy with the results.
    I got supernova V.4s from headlight revolution.
