New to tundra and need advice
Discussion in 'General Tundra Discussion' started by Stewart, Feb 7, 2019.
  1. Feb 7, 2019 at 8:31 AM
    Stewart
    Stewart [OP] New Member
    hello folks, I’m new to the tundra and need a bit of advice, I just bought my first Toyota and it has a leveling kit on it, it measured 2”, but the back is stock, the front end looks higher then the back and I just don’t like it at all, I’ve been researching a lot and I seen where I can buy toytec shackles and put on the back and make it more level, but would it be any easier to just pull the lift spacers off the front coil springs? I’m more of a stock truck kinda guy with the exception of aftermarket wheels maybe??? What would do me best? Is the spacers hard on the front at all? Or should I take em out? By the way my teuck is a 2014 ext cab 4x4 tundra with the 5.7
  2. Feb 7, 2019 at 8:34 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's easier to install shackles than to remove spacers. That said, urinal cake spacers are not desirable as they make the ride a little harsher (preloading the springs) and can cause shock failure in some (generally off road) situations.
    Stewart[OP] and Black Wolf like this.
  3. Feb 7, 2019 at 8:36 AM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    just pull them out, front end will last longer
    Stewart[OP] likes this.
  4. Feb 7, 2019 at 9:37 AM
    Welcome from Ohio.
  5. Feb 7, 2019 at 9:42 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  6. Feb 7, 2019 at 9:59 AM
    Stewart
    Thanks y’all I’m from florida
  7. Feb 7, 2019 at 10:29 AM
    Welcome from CO.
  8. Feb 7, 2019 at 11:25 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I guess I’ll bite but
    :worthless:
  9. Feb 7, 2019 at 1:43 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut
  10. Feb 7, 2019 at 1:58 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Pulling out is the way to go..:thumbsup:
    Stewart[OP] and Alexstundra like this.
  11. Feb 7, 2019 at 3:04 PM
    Stewart
  12. Feb 7, 2019 at 3:06 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from Texas!
  13. Feb 7, 2019 at 3:13 PM
    Welcome from NY.
  14. Feb 7, 2019 at 6:10 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I would leave the spacers in since they’re already there. You’ll have to pay labor to have them removed and get an alignment. This will cost more than just adding shackles or blocks to the rear. If it’s the above coil type spacer that doesnt put a preload on the coil, they won’t do any harm at all and won’t affect your ride. You may regret taking them out if you want to get bigger tires etc.. You can in inexpensively add 1” to the rear by adding a shackle lift or a couple blocks. This will make your truck look a lot better by adding a touch of factory rake back to it.
