Old man emu suspension
Discussion in 'Suspension' started by Dustydirt19, Aug 29, 2016.
  1. Aug 30, 2016 at 11:16 PM
    #61
    There are many different AAL's available out there. They are not all the same. Different thickness', length, force/tension factors to consider when added to OEM leafs or aftermarket leafs . It's all about finding the right one for your needs. I personally try to avoid blanket statements about anything. Don't want to steer anyone wrong. Hearsay is not a factor I go by.
  2. Aug 31, 2016 at 5:09 AM
    #62
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    You're suggesting to skip the aal's all together and stay oem leafs, shackles and air bags?
  3. Aug 31, 2016 at 5:11 AM
    #63
    Dustydirt19
    Dustin
    Duluth, MN
    I was kind of more just curious about the Toytec shackles vs the coachbuilders
  4. Aug 31, 2016 at 5:29 AM
    #64
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Coachbuilder shacklers are MUCH beefier than Toytec shackles. Practically everyone who has them can't say enough nice things about them.
  5. Aug 31, 2016 at 6:24 AM
    #65
    Dustydirt19
    Dustin
    Duluth, MN
    They beefier they are does that make the ride any different or just less chanice of busting?
  6. Aug 31, 2016 at 8:16 AM
    #66
    chphilo
    Western PA
    Beefier shackles will lessen the chances of side-to-side sway with long shackles.
  7. Aug 31, 2016 at 8:21 AM
    #67
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    CB shackles are bolt together aluminum. Toytecs are 3/8" welded steel.
    I know where I would put my money on which is stronger. Hint hint steel.
    Toytecs are also only $139.
    Black Wolf likes this.
  8. Aug 31, 2016 at 8:23 AM
    #68
    csuviper
    Broomfield, CO
    Yes that is what I have done. If you have constant load in the bed then aal would be good. If you tow then add air bags for a great ride when loaded.
  9. Aug 31, 2016 at 8:26 AM
    #69
    csuviper
    Broomfield, CO
    True you could go with the Icon progressive aal that gives 1.5" of lift.
  10. Aug 31, 2016 at 8:34 AM
    #70
    chphilo
    Western PA
    Steel is stronger for the same size. Coachbuilder shackles are substantially larger than either Toytec or Toyota shackles.
    Anyway, I have neither Toytec nor Coachbuilder shackles. I was sorta planning to get some upgrades, but other mods got done first, haha. But those who have them seem to love them . . . whole lot. FYI, here is a poll taken about this over at another forum.
    http://www.tundratalk.net/forums/tundra-suspension-talk/569970-coach-builder-happy-regret-3.html
  11. Aug 31, 2016 at 8:50 AM
    #71
    ToyTec shackles are pretty much the same size dimensionally and solid welded as in no weak points.Not bolted together. ToyTec shackles are pretty freaking beefy. They dwarf OEM shackles. Can't go wrong with either shackles. $139 for ToyTecs is a steal.
  12. Aug 31, 2016 at 2:02 PM
    #72
    chphilo
    Western PA
    These are the Coachbuilders shackles I am talking about (first three). The last one, I believe is Toyota shackles.
    ToyTec shackles seems to be of similar thickness as the OEM shackles.
    ColoradoTJ, Law323 and CaptTyler like this.
  13. Aug 31, 2016 at 2:34 PM
    #73
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Im sure either shackle would be an excellent choice.
    I PERSONALLY chose the CoachBuilder +2. They are so stout and well built and David is such a great person to deal with. He will work with you every step if you need any help. Like I said...can't go wrong either way.
    Law323 likes this.
  14. Aug 31, 2016 at 2:38 PM
    #74
    csuviper
    Broomfield, CO
    Toytec vs stock
  15. Aug 31, 2016 at 5:45 PM
    #75
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I was gonna say.... every truck ive seen with ome suspension looks pretty large....
  16. Aug 31, 2016 at 10:55 PM
    #76
    Dustydirt19
    Dustin
    Duluth, MN
    All good stuff. I'm gonna go with the Toytec shackles just so everything stays the same. Toytec all around
  17. Sep 1, 2016 at 5:16 AM
    #77
    Way different than OEM shackles. Way different. Very solid. No flexing with these.[​IMG]
    chphilo likes this.
  18. Sep 1, 2016 at 5:21 AM
    #78
    I know you saw my coil overs up close and personal. heh heh.. Pretty decent for the price.
    LOTSOFTOYS[QUOTED] likes this.
  19. Sep 1, 2016 at 10:31 AM
    #79
    chphilo
    Western PA
    Thanks for the pictures of ToyTec shackles. The side by side shot with Toyota shackles is really helpful. They do look sweet. Definitely an option if I decide to do shackles.
  20. Sep 1, 2016 at 4:38 PM
    #80
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Any specific reason you'd go with the boss rear shocks?
  21. Sep 1, 2016 at 8:07 PM
    #81
    I asked the ToyTec gurus up close and personal if I should get the new Boss shocks for the rear. Same price. Said to to with the matching OME Nitrocharger rears. Nothing to do with Boss rears being inferior. The Boss are great.
  22. Sep 2, 2016 at 6:32 PM
    #82
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I went with boss because they are slightly longer. The ome shocks are great but they also limit the Dakar springs.
  23. Oct 6, 2016 at 11:29 AM
    #83
    Dustydirt19
    Dustin
    Duluth, MN
    Did you have the fated driver side lean at all with the boss set up? Was just wondering if I should order shims at all when I get my lift?
