Timing belt change... broken truck - please help
Discussion in '1st Gen Tundras (2000-2006)' started by turf, Feb 3, 2019.
  1. Feb 3, 2019 at 6:53 PM
    turf
    turf [OP] New Member
    hi there,
    i started changing the timing belt yesterday and today the truck is broken good.
    i have had nothing but problems and now am regretting attempting the belt change.
    at this point, the motor only turns about a quarter turn either direction and hits a hard stop.
    i've had trouble removing the main pulley, but when it came off, 3 mystery pieces showed up. i now have a spring, a bearing and small metal rod that i have no clue where they came from.
    the crank moved when pulling the pulley, both cams have moved trying to line up the marks. how do i get back to zero and start over?
    left over parts
    qG_xLvtqa109eIJCmPD--R_zMw4du6l49R3nW3oQ_6a1326023f61465f97fb3bf2070702515a5568ab.jpg
    any help appreciated!
  2. Feb 3, 2019 at 9:11 PM
    turf
    what would be the hard stop either direction on the main crank? this doesnt sound good.
    the left over parts may be from a swivel socket i broke trying to get the crank pulley off.
  3. Feb 3, 2019 at 9:15 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s a Sunday night after the super bowl. Hopefully someone with some help will chime in. You might need to be bump your thread tomorrow when folks may be more active.
  4. Feb 3, 2019 at 9:27 PM
    Casper421
    In the woods
    06 DC
  5. Feb 3, 2019 at 9:35 PM
    turf
    i got the pulley off by bumping the starter. i had taken the timing belt off of the cams before i did the starter. the remaining belt wedged up around the crank a half a turn and bent the toothed thingy.
    now the crank hits hard (bang) stops about a quarter to half a turn apart.
    thanks, i forgot about the superbowl, this dang timing.
  6. Feb 4, 2019 at 6:01 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That's some lousy luck. You'll probably need to at least pull the valve covers to get an idea of where the valves are at. Hopefully the hard stop you're getting isn't from hitting a valve.
    If I get a chance this afternoon I'll get the service manual pages for resetting everything.
    turf[OP] and 15whtrd like this.
  7. Feb 4, 2019 at 6:22 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    You can’t turn the crank without turning the cams in exact time with it. Well you can, but you won’t have much of an engine left if you do. The valves and pistons occupy the same space at some points... that’s why cam timing is so important. You’re probably hearing a valve and a piston loving on one another.
    kenomouth64 likes this.
  8. Feb 4, 2019 at 6:42 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I believe the 2003 VVti 4.7l motors are an interference engine, so the hard stop might be a valve and piston hitting one another.
  9. Feb 4, 2019 at 7:09 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    This is what you need to do
    1. Google up a tow truck, or a uhaul and a car hauler go get either.
    2. Google "mechanic"
    3. Read google reviews
    4. Delete funds from bank account, head to shop
    5. Apologize to mechanic for any mess you made, usually a case of beer is an acceptable offering, along with lots of $$$$
  10. Feb 4, 2019 at 8:17 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Probably need to pull the heads at this point since you bumped the crank with the starter
    Then you should have the ability to turn the crank by hand to do what you need
    Or as others have said have it towed to a shop and let let them repair it.
  11. Feb 4, 2019 at 10:49 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    This.....professional help time.
  12. Feb 4, 2019 at 11:00 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I changed my '05 2uzfe belt twice and a friend's '00 2uzfe once. It's driveway doable if you have patience. The first time I did it on my '05, I had a ton of problems and had to disassemble it to get the cams aligned with the belt correctly, then disassemble again to fix a leaking water pump gasket. I bet your belt and cams aren't aligned properly. That part was a PITA every time. There are a couple great Youtube vids to watch, the one with the mex music playing, from the Toyota Tech, was the best to watch. This guy https://youtu.be/Z46cM-Bw1rI
  13. Feb 16, 2019 at 4:58 PM
    turf
    4 broken valves.
    whats a good source for used engines?
  14. Feb 16, 2019 at 5:33 PM
    Rubberdown
    Did it actually destroy a piston? Should be able to take heads to a machine shop and have heads rebuilt with new valves... at least you know what you have then.
    turf[OP] likes this.
  15. Feb 16, 2019 at 5:50 PM
    turf
    the mechanic cant see the piston surface, he just said there were 4 valve heads and some metal on top of the piston(s)
  16. Feb 16, 2019 at 6:04 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    www.car-part.com has a bunch of listing under $1k or you can do an ATK reman for about $4k
    turf[QUOTED][OP] and Sunnier like this.
  17. Feb 16, 2019 at 6:19 PM
    Aerindel
    Aerindel New Member
    Montana
    The pistons are almost certainly fine. I had a subaru break a timing belt while driving, which destroyed a all the valves on one side but just put some dings in the piston. I got a new head from a JDM importer and drove the car for another five years. If this where me that is what I would do.
    Sorry you killed your engine. Now you know why the manuals say never turn the engine with the timing belt off.
