Weird noise coming from front driver side
Discussion in '2nd Gen Tundras (2007-2013)' started by Ironbull Tatts, Jan 30, 2019.
What can it be
  1. A
    0 vote(s)
    0.0%
  2. B
    100.0%
Multiple votes are allowed.
  1. Jan 30, 2019 at 7:06 PM
    Ironbull Tatts
    Ironbull Tatts [OP] New Member
    I recently started to hear a noise in the front driver side it sounds like something is scrapping....metal to metal sound...it had gotten worse now it sounds like the brake pads are rubbing on rotor the pedal vibrates a little too, inside the cab....it only does it as the car starts to run after it has been off for a while ...on w the car runs for a couple hundred feet noise goes o
  2. Jan 30, 2019 at 7:13 PM
    Welcome from NY.
    Did you check your brake pads?
    I voted B .....for Brakes:rofl:
    A & B are blank.
    Black Wolf and Adriver71x like this.
  3. Jan 30, 2019 at 7:30 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Brakes or wheel bearing.
    Stormtrooper81 likes this.
  4. Jan 31, 2019 at 3:31 AM
    Ironbull Tatts
    I checked the brake pads they still got plenty on them ..I checked also the rotors , brake pump and booster, reservoir....all your basic components ...all ok . .. no leakage...I did notice a small kind of scratch/ groove to say on the driver rotor but no marks or sign of wear on pads...
  5. Jan 31, 2019 at 4:23 AM
    Dr_Al
    Dr_Al New Member
    Al
    I had a '90 Celica All Trac Turbo that had a problem with the anti-lock brakes. When you first started it up (after it had been sitting for a little while) it would make a grinding noise once I started to move. It would go away after maybe 50 feet. It turns out that the computer was turning on the anti-lock brake pump to test it. Somehow a little grime had gotten into the the motor and that's what I was hearing. When I disconnected the power to the pump, I got check engine lights, but the noise didn't happen. I was able to take it apart myself and clean it up. This was outside of the hydraulic system.
  6. Jan 31, 2019 at 5:05 AM
    timsp8
    NY
    Brake backing plates bent?
  7. Feb 3, 2019 at 1:44 PM
    ToyoTim
    ToyoTim New Member
    Ottawa, Ontario
    2021 TRD Sport Premium 4x4
    That’s what I was thinking as well. My backing plates are rusted and bend easily, after doing a rotor/pad change out they started scraping...drove me crazy!
  8. Feb 4, 2019 at 3:51 AM
    Ironbull Tatts
    So I think I finally got to the heart of the issue .....the rear wheel bearing seems to be making a noise ...after a long diagnosed on pads , calipers , etc. ...the wheel bearing seems to have gone out which in return knock off the wheel sensor which in return is triggering the abs system....the noise i hear everytime the truck has been sitting is the computer testing the ABS system just like that Celica ....hopefully replacing the pressed on bearing will do the job and I'm praying that the shaft is not damaged from the bearing ....I will keep you guys posted
  9. Feb 4, 2019 at 4:03 AM
    timsp8
    NY
    I think there is a tsb for the rear wheel bearings. Had to replace mine in my 2010. Made a grinding noise going around curves. If you search it seems common. But expensive.
