Found a new solution to the big brake upgrade. It uses 14WA calipers which utilize a larger pistons, 1” larger rotor and the bolt pattern is a perfect match. All you have to do is either trim the caliper mounting tabs or the knuckle assembly itself to align the rotor to the caliper.
