Yellow Stuff
Discussion in '2.5 Gen Tundras (2014-2021)' started by UTAHRTK, Oct 1, 2020.
  1. Oct 1, 2020 at 10:58 PM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    Are EBC Yellow Stuff pads the way to go? Thinking Stop Tech Slotted rotors and having them frozen and using EBC yellow pads.
  2. Oct 1, 2020 at 11:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's my exact setup. Stopping distance was seriously increased after going to 37s. With the Stop Tech and yellows it seems better to me than stock. They're dusty AF and hard on rotors but it's worth it to me to be able to stop quickly. They also don't last long, I just bought another set after only about 12-15k mi.
  3. Oct 2, 2020 at 6:46 AM
    UTAHRTK
    SOCAL
    Thanks. Good info.Did you get the rotors frozen? Wondering general costs for that- Im thinking 50 bucks ea.?
    831Tun likes this.
  4. Oct 2, 2020 at 7:06 AM
    timsp8
    NY
    I just changed from power stop to ebc orange and there was a difference in stopping and pedal feel. Ebc bedding process is different from any other pads I’ve used so read up on that if you go to ebc. That way you’ll get better performance and life.
    I think you can order the stop tech already frozen. Check autoanything.
  5. Oct 2, 2020 at 7:07 AM
    UTAHRTK
    SOCAL
    Cool. I will check it out.
  6. Oct 2, 2020 at 7:13 AM
    timsp8
    NY
    Autoanything gives the cryo option on a couple of stop tech models. Looks like it adds about $26. $167 total.
    https://www.autoanything.com/brakes/61A7566A0A0.aspx
    Edit
    Looked again and it’s only on the rear left. I wonder if they are just out of stock. Might want to call if you think that’s a good price.
  7. Oct 2, 2020 at 7:16 AM
    UTAHRTK
    SOCAL
    Hell yea - Autoanything offers a cryo option- 30 bucks! Sweet. Im guessing I should replace all pads -frnt/rear? Was planning replacing front rotors only. Do you all recommend upgrading the brake lines ? How about fluid?
  8. Oct 2, 2020 at 7:40 AM
    timsp8
    NY
    If it was me, I’d replace all at the same time. Your rears might not need replacing as bad, but you know you will have to eventually and can get it all done at once. I wouldn’t change brake lines unless you have a lift and need longer ones. You could strip something or get dirt/rust in the line. Even in SoCal I’d bet yours have some rust on them.
    I’d flush the lines too. It’s only the cost of 2-3 bottles of fluid. Takes about 25 or so pumps for the rears and 10-15 for the fronts. I used motul 5.1, but there is a thread about Bosch 5.1 that makes it sound better.
  9. Oct 2, 2020 at 7:43 AM
    timsp8
    NY
  10. Oct 2, 2020 at 7:45 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No I didn't. Be interesting to compare the difference
  11. Oct 2, 2020 at 5:39 PM
    UTAHRTK
    SOCAL
    I believe longevity is the benefit.
    831Tun likes this.
