WTF Do I Know...Recommended Mods
Discussion in '2.5 Gen Tundras (2014-2021)' started by metalsideup, Jan 18, 2019.
  1. Jan 18, 2019 at 8:39 PM
    metalsideup
    metalsideup [OP] New Member
    Greetings Folks. I only joined this outfit today, but I did so to learn from other enthusiast about mods I can make/do to my truck that will make it more functional to me. Unfortunately, I'm not the guy that wants to know how to put a Tundra Pro grill on my SR5 or raise my truck 20 inches. I bought my original 2008 Tundra by stepping up from a 2003 Tacoma, all because my life style required the extra room. And my household only consists of me and a dog. But my needs have changed. I recently moved to a 2019 SR5 Double Cab. Time to modify.
    I live in Colorado, I am also retired, so I am always on the road with the thing. I do day trips, I do extended road-trips, and most often these trips involve a rifle or fishing gear, a camping trailer, a solar panel, a bicycle, camera gear (yea drones!), and a canoe. So the sacred money that gets tossed upon my truck needs to net some sort of measurable improvement in utility. I am not a Tundra Snob. I don't give a crap about what wheels I have. I want a tool that jives with me like a good girlfriend, and doesn't suck away my budget on chrome bling. I search and adopt only the things that improve my status quo by way of making an immediate improvement in efficiency. With that said, here's is my simple list of things to consider when throwing money at our Tundra's, listed in order of MY priority:
    1). A good bed cover, called a tonneau cover. Endure the hit and buy one that is resistant to the elements in your area. If it locks, you are very smart. My favorite is pricey, but it falls in that "cry once... but then smile often" category. Search Diamondback Covers.
    2.) IF you have invested in a tonneau cover, buy the $88 Pop&Lock tailgate lock-but only if you have doors that lock via a remote fob. This kit is fairly easy to install if you have basic wiring knowledge... or can get it. Just take your time and have fun. Once installed, it will lock your tailgate anytime your truck doors get secured. Obviously, this is only suitable if your bed/cargo area is already covered.
    3.) Upgrade the floor mats to a brand that really does collect & pool whatever you introduce into your truck's interior. This can be sand, water, snow, or mud. Floor mats are like knives; they are all designed for specific uses. Ponder your over-all truck environment, research your options, then pull the dollar trigger.
    4.) Truck bed lights. Do your research, but DO NOT endure the 10 years of holding a flashlight in your mouth like I did (if you can find it & if it wants to turn on). I like a new system offered on Amazon that employs capacitive touch on/off, marketed towards boats & campers. Robin Electronics. You have to be friendly with wiring though.
    5.) Add a 3-port 12vdc cigarette-type outlet. My 2019 Tundra shuts down all the 12vdc charging ports once the key is removed. There are times, times I can count on both hands and feet, where to have my phone/device charging while I am in a cafe would be quite handy. To NOT have that option sort of tisses me off. So, go on Amazon, find one that will meet your needs, and wire that baby up direct to momma battery. Don't neglect adding a plug-in QualCom-rated high-amp charger into your new 3-port if you have devices that are fast-charging capable. Again, let the high ratings be your guide.
    6.) AMP or Bestop bedstep. IF your Tundra model can accept one of these products, and my understanding is the Tundras with "plastic" bumpers can not, I HIGHLY recommend their purchase and install. Either works, they are almost clones. The AMP is better quality, but the price premium is debatable. I went with Bestop for my next 10 years of bed stepping.
    7.) Don't laugh, but exchanging your OEM 31" antenna for a 6" rubber ducky type can save you money if you ever go thru a robotic car wash. They aren't all the same-just buy based on 5 star ratings and you will be happy. They look cool too!
    8.) If you tow a trailer, consider adding the TRD anti-sway bar on the rear. Google, read, and make your own decision.
    9.) If you travel like a retired guy out west, you will inevitably or occasionally spend a lot of time way-way away from AM/FM/TV towers. Having SiriusXM radio can be quite stimulating coupled with your morning coffee. Do your research.
    10). My last suggestion is prone to being scoffed by the don't-use-my-truck-like-a-truck crowd. But, for the dollars, I would rate this baby as my best Tundra investment...OK, tied with my bed cover. It is on Amazon, made by Access Covers, and is called the 70950 EZ Retriever II. At first, my McGuiver personality thought I can make that. But, due to circumstances placing me away from my garage, I had to pull the trigger. I use my truck a lot, and I love this thing.
    Enjoy your 4-wheeled tool, and post me your must-haves.
  2. Jan 18, 2019 at 9:15 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Welcome. I am a new guy too. You have a very specific set of needs. I do too, except it is much different. I drive 30K a year, mostly on interstate. I pull different trailers, depending on need. It might be a 1400 lb or a 7K lb trailer, depending on what my job needs. I might go several months without pulling anything. So versatility is key.
    I know that bed covers are for honest people. If someone wants in bad enough they will get in. I think the OEM will work best for me because I use it for water resistant storage while traveling only. Not storage.
    I drive a ton in the snow and rain so best wiper blades, fluid and tires are extremely important. I also go off road but not for fun so much. More to get to a job site. Could be miles, could be only a few hundred yards.
    In addition, I might be by myself or I might have the CEO and COO in my truck. The next day I could have three engineers. The next night be me and my wife and my dog. So interior choice is key and back seat protection. I am looking at a Crew Cab Limited.
    Bottom line, must have are very individualistic, depending on use.
    Black Wolf likes this.
  3. Jan 18, 2019 at 9:41 PM
    gosolo
    Ray
    NW Oregon
    A few additional mods to consider are:
    1) rear seat back fold down mod (free)
    2) drivers side grab handle ($140 +/-)
    3) locking steel box for the center console (several to choose from and a bit pricey, but pretty nice for locking stuff up)
  4. Jan 19, 2019 at 4:57 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut
  5. Jan 19, 2019 at 4:59 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  6. Jan 19, 2019 at 5:16 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Welcome from Aurora.
  7. Jan 19, 2019 at 5:20 AM
    Welcome from Ohio!
  8. Jan 19, 2019 at 5:55 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Welcome!
  9. Jan 19, 2019 at 6:39 AM
    Krezz and 1engineer like this.
  10. Jan 19, 2019 at 6:39 AM
    Welcome from Texas
  11. Jan 19, 2019 at 6:51 AM
    pughfish
    pughfish New Member
    William
    NC
    2022 Tundra Celestial Silver Metallic, Capstone
    Welcome from NC!
  12. Jan 19, 2019 at 7:14 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Welcome from TX!
    Add:
    -LED interior lighting. The illumination is so much better. A retiree will appreciate this.
    -Console organizer and tray, Salex makes good stuff.
    Hillbilly Taz likes this.
  13. Jan 19, 2019 at 7:22 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  14. Jan 19, 2019 at 7:37 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  15. Jan 19, 2019 at 7:54 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  16. Jan 19, 2019 at 8:03 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Welcome from WY. I 2nd the driver side grab handle. Best mod ever, you will use it every day. Gift that keeps on giving the whole year through Clark!
  17. Jan 19, 2019 at 8:04 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    Welcome from Idaho, those were good suggestions.
  18. Jan 19, 2019 at 8:05 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Welcome from SoCal. That's a very impressive list. There is no right-or-wrong when it comes to mods. We've all got damn fine trucks that can be used for all sorts of things. In my experience, most of the folks on here will gladly share their experiences if you're willing to ask.
    Can we see what the new rig looks like?
    15whtrd likes this.
  19. Jan 19, 2019 at 8:33 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    This made me laugh but I did read it all hahaha.
    Welcome to the show man
  20. Jan 19, 2019 at 8:37 AM
    I read it all too :oops:
    Krezz[QUOTED] likes this.
  21. Jan 19, 2019 at 8:38 AM
  22. Jan 21, 2019 at 9:49 PM
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    Seeking alternative bed step suggestions compatible with 19 Platinum. AMP and Bestop not offering beyond 2018. Thanks
    AMP-Research replied, they do offer for 2018+.
    Bestop replied not currently available no additional information.
  23. Jan 31, 2019 at 6:04 AM
    Baja1000
    Baja1000 New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    Hey guys Is the drivers side grab rail a Toyota part or can I get it on Amazon?
    Thanks!
  24. Jan 31, 2019 at 6:24 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I ordered the parts for it from megazip. Was cheapest option I could find. See the OEM parts thread for links on needed parts and maybe a few other things you might need.
    Baja1000[QUOTED] likes this.
  25. Jan 31, 2019 at 6:40 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Welcome from East TN! Thanks for the tips!
  26. Jan 31, 2019 at 6:43 AM
    alpinepro4
    Pat
    Baja1000 likes this.
