Wrapped window trims ???
Discussion in '3rd Gen Tundras (2022+)' started by Welderdude80, Jan 31, 2023.
  1. Jan 31, 2023 at 3:24 PM
    Welderdude80
    Welderdude80 [OP] New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    Thinking of getting mine done on the limited. Anybody did it ? How does it look. Pics ??
  2. Jan 31, 2023 at 4:29 PM
    Tikisia
    Tikisia New Member
    I did it and looked good, BUT I damage the seals so order the black trims.
    I used piano black. If you do it or have anyone do it, they will need to be really careful when they trim the excess so they/you don’t do what I did and damage them.
    No photos since I replaced them, sorry.
  3. Jan 31, 2023 at 4:38 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    It was cheaper to buy new OEM black trim than it was to get the chrome wrapped over in black. I would recommend buy new trim
    V3N0M likes this.
  4. Jan 31, 2023 at 4:42 PM
    Welderdude80
    JP
    Alberta
    working on it
    im getting moustache, rear bumper panel and window trims for 800$cnd. I've been told $300 to wrap window trims. couldnt find anything cheaper by buying black trims.
  5. Jan 31, 2023 at 4:48 PM
    Cp1
    Cp1 New Member
    Chad
    2023 tundra limited 4x4
    Does anyone happen to have the part numbers for the black window trim?
  6. Jan 31, 2023 at 4:51 PM
    Welderdude80
    JP
    Alberta
    working on it
    Yaboy likes this.
  7. Jan 31, 2023 at 4:53 PM
    Cp1
    Cp1 New Member
    Chad
    Thank you! Welderdude
  8. Jan 31, 2023 at 5:35 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    If you can get it done for $300 then it’s worth a try, my quotes were over 1000
  9. Jan 31, 2023 at 5:38 PM
    Cp1
    Cp1 New Member
    Chad
    The guy who quoted me said it only lasts about 5 years?
  10. Jan 31, 2023 at 7:24 PM
    DeafJam
    DeafJam New Member
    Louisiana
    2023 Toyota Tundra Hybrid, 1794 edition
    Cosmetics for for a pavement princess.
    They sell vinyl tape for this and it isn’t expensive.
    This is probably an hour long job to complete if you have limited to no skill. An hour and a half if you need to watch a couple YouTube videos prior to doing it. These are simple parts, so the skill level required isn’t very high.
  11. Jan 31, 2023 at 9:03 PM
    Welderdude80
    JP
    Alberta
    working on it
    $1000 for window trims ? Wtf
  12. Jan 31, 2023 at 9:18 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Tell me about it, so I spent $1000 on new trim that is a permanent fix. Total chrome delete on my Canadian limited cost $2200 with painting the other parts.
  13. Jan 31, 2023 at 9:20 PM
    Welderdude80
    JP
    Alberta
    working on it
    Ouch.
    Yaboy[QUOTED] likes this.
  14. Feb 1, 2023 at 5:09 AM
    Limited 23SC
    Limited 23SC New Member
    2023 Limited
    Im just goingto plastic dip mine and see how long that lasts. Already did the 4x4 and tailgate handle.
  15. Mar 30, 2023 at 11:44 PM
    trdskyline
    trdskyline New Member
    2023 LunarRock Limited Hybrid CrewMax
    Satin Black 3M vinyl window trim
  16. Mar 31, 2023 at 7:14 AM
    PikesPeakTRD
    PikesPeakTRD New Member
    23 Hybrid Limited TRD OR MGM
    I like that! Did you wrap the door handles as well?
  17. Mar 31, 2023 at 8:13 AM
    trdskyline
    Yes handles wrap same as window trim
  18. Mar 31, 2023 at 7:10 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Looks great! Curious why you decided on satin rather than gloss to match the pillars and under mirrors?
  19. Mar 31, 2023 at 9:57 PM
    trdskyline
    I actually was debating and just decided to match the LIMITED badging and contrast the top of handle gloss. Just fyi I already have a tiny nick in the vinyl exposing the chrome underneath, not sure from what. Will leave as is until I get more then maybe go oem route.
  20. Apr 1, 2023 at 8:52 AM
    estebanoss
    estebanoss New Member
    '23 Limited 4x4 TRD OR
    Wrapping the window trim is fairly straightforward. But like someone up there said, it's fairly easy to cut into the rubber seals if you're not careful.
    I did a gloss black vinyl and it looks good, but in some spots the chrome is starting to show through from any rock chip or from the vinyl shrinking.
    Probably just going to purchase the OEM black trim and be done with it.
  21. Apr 1, 2023 at 3:00 PM
    ArticTundra
    ArticTundra New Member
    Cold
    I might try Plastidip....can't hurt.
  22. Apr 2, 2023 at 8:34 AM
    trailhunters
    trailhunters New Member
    Wrapping is extremely tricky. The seals get cut while trimming excess. Make sure you bring this up as a concern with your installer.
  23. Apr 3, 2023 at 11:03 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
  24. Apr 4, 2023 at 1:32 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    iiawah808[QUOTED] likes this.
  25. Apr 4, 2023 at 2:01 PM
    iiawah808
    Oahu, HI
    Lololol
  26. Apr 5, 2023 at 12:26 PM
    weshoover
    weshoover New Member
    Wes
    2022 tundra crewmax lb trd off road
    I did mine in gloss black plasti dip. one thing i will note is that the gloss black is very runny. If i was going to do it again I would do the regular black and then the glossifier.
    Cdunner and iiawah808 like this.
  27. Apr 16, 2023 at 4:13 AM
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    I wonder how long will this hold up. I would like to get rid of the chrome trim on my sr5 23 sequoia. May ask the dealer for platinum or pro prices.
  28. Apr 17, 2023 at 3:54 AM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    I plastidipped my front hybrid bumper on my Tacoma. It outlasted the truck before trading it in. No chips or rust, honestly I was really surprised. Went with the dip for touch ups if needed but never did
  29. Apr 18, 2023 at 3:44 PM
    weshoover
    Wes
    I've done plasti dip on past vehicle even did a whole car once it lasts for years and if after 2 or three years it starts to wear you can always peel it off and re do
    Cdunner[QUOTED] likes this.
