Would you feel safe with this tight of a payload?
Discussion in 'Towing & Hauling' started by ImagineThat, Dec 28, 2019.
  1. Dec 28, 2019 at 3:09 PM
    ImagineThat
    ImagineThat [OP] New Member
    2018 Tundra Platinum CrewMax Short
    Hello, and thank you for the inclusion in this forum.
    We have a 2018 Tundra Platinum, Crewmax 5.7 V8 with a payload of 1185.
    Looking at a TT with 515 pound hitch weight. Two passengers in truck for a total of 400 pounds.
    Not planning on hauling anything in the truck except us.
    Would you feel comfortable with this? FYI: 2020 Imagine 2250RK travel trailer
    jtwags likes this.
  2. Dec 29, 2019 at 2:03 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I would absolutely feel comfortable with this payload which is within spec. Are you using a weight distribution hitch?
    ATHiker and ImagineThat[OP] like this.
  3. Dec 29, 2019 at 2:18 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    That is about what we tow too with 2018 crewmax 4x4, same payload as you. Get a weight distribution hitch and load the trailer evenly to keep pin weight within spec of the tundra payload and it will tow great.
    ImagineThat[OP] likes this.
  4. Dec 29, 2019 at 2:32 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Piece of cake.
  5. Dec 29, 2019 at 3:24 PM
    Aerindel
    Aerindel New Member
    Montana
    Of course. Towing capacities have a pretty big margin before your truck actually snaps in half and kills you.
  6. Dec 29, 2019 at 3:27 PM
    ImagineThat
    Wow, this is a completely different response than what I have gotten from the folks on a few different RV forums. Thank you very much.
  7. Dec 29, 2019 at 3:29 PM
    ImagineThat
    Does anyone have a recommendation of a good WDH? Should I just go with the Husky that the RV dealership includes in the deal or get one of the premium ones I hear people talk about (Hensley, EQ, Anderson).
  8. Dec 29, 2019 at 3:44 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Welcome to Tundras.com. I have had a coversation with you on the GD FB page lol. Lots of good info on this site.
  9. Dec 29, 2019 at 3:45 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Gvwr is only 6995 on the trailer. Even loaded down, That’s well within spec. It will tow just fine.
    BravoDeltaRomeo likes this.
  10. Dec 29, 2019 at 3:56 PM
    ImagineThat
    Thank you for your input. My concern was with the payload, not GVWR (although i know that factors in). It has been a rubics cube and significant learning curve but I think I am getting there!
  11. Dec 29, 2019 at 3:57 PM
    ImagineThat
    Oh dear. Were you one of the cool ones or the rude ones? :)
  12. Dec 30, 2019 at 7:39 AM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I have same. 500 hitch weight after I loaded everything up and about 5000lbs.
  13. Dec 30, 2019 at 7:42 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Welcome.. I have a easy lift system. I heard that the equalizer is the better than what I have.
  14. Dec 30, 2019 at 7:42 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    How does ur camper weigh?
  15. Dec 30, 2019 at 8:08 AM
    ImagineThat
    hitch weight 515 GVWR 7000
  16. Dec 30, 2019 at 8:15 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    You will be fine with the Husky WDH that is included, as long as it has been set up properly. My 14 has about 1300 payload. The trailer we tow has 550 lb tongue. Passengers and Cargo push 700 lbs. By the math, we are cutting it really close. However, we've never experienced any issues and the Tundra handles everything very well. We have "generic" WDH that I have played around with and adjusted just right for our rig.
    I think the Tundra's payload is a little under rated. Plus, the WDH helps to manage the load and distribute some of the weight back to the trailer's axles. Most important thing is to check your tires for proper inflation for trailer and tow vehicle.
    Edit: just saw your last post with the hitch weight and GVWR. Looks like your hitch weight is based on unloaded weight. Generally, you will want the hitch weight to be about 12-15% of your loaded trailer weight for stability purposes.
  17. Dec 30, 2019 at 8:48 AM
    ImagineThat
    Great, so, we wont be loading the trailer to the max of 7000 BUT, if we did, then 12 percent is 840, plus 400 for my husband and I (people argue about whether payload includes one driver at 150 pounds) brings the payload up to 1240....SO....55 pounds over my 1185 payload of the Tundra. This seems reasonable. Agree?
  18. Dec 30, 2019 at 8:51 AM
    gdiep
    Syracuse, New York
    I sent you a PM about being careful with RV dealer's advertised weights. With the example you used above, if those were the true weights, I wouldn't have any concern. But that is just me and my comfort level towing a travel trailer with the Tundra.
  19. Dec 30, 2019 at 9:15 AM
    ImagineThat
    Thank you for taking the time to PM me additional feedback. I bought a Sherline tongue weight scale and will measure it myself. It is also possible the payload weight limit on the Tundra is underrated. The best I can do is to take the manufacturer recommendations and try to stay as close to that as possible and then hope for the best.. :)
  20. Dec 30, 2019 at 4:22 PM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    Tundras Payload ratings are under rated. But better super safe than sorry I guess......
  21. Dec 30, 2019 at 4:59 PM
    ImagineThat
    Found a CAT scale very near me. Looking forward to weighing everything.
  22. Dec 30, 2019 at 5:06 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Let us know. Is ur truck stock?
  23. Dec 30, 2019 at 5:20 PM
    SouthWestGA
    SouthWestGA New Member
    Don’t forget to weigh it with a full tank of gas in the truck
  24. Dec 30, 2019 at 6:34 PM
    ImagineThat
    Yes, it is stock. It does have the optional extra large 38 gallon fuel tank and the tow package. But no mods, if that what you mean.
  25. Jan 1, 2020 at 4:31 AM
    jstyle
    jstyle New Member
    Josh
    2016 Magnetic Gray Offroad CrewMax
    I have the Husky Centerline WDH with 800lbs bars https://www.etrailer.com/Weight-Dis...GQdKCPyA8BjH0tC79Ex8NKykCwOGSXKBoCt1sQAvD_BwE on my 2016 5.7 CrewMax and I tow a 2019 26” Grey Wolf. My empty weight is 6200 with 725lbs tongue weight... but I have two full propane tanks, a now dual battery set up, even fully loaded with a full fresh tank and everything I don’t even know it’s there. I love the set-up so no complaints from me.
