Wood grain dash change and existing radio does not fit
Discussion in 'New Member Introductions' started by 2004tundrasr5oem, Dec 25, 2020.
  1. Dec 25, 2020 at 10:59 AM
    2004tundrasr5oem
    2004tundrasr5oem [OP] New Member
    2004 tundra access cab
    Hello, I am new to this forum. I have a 2004 access cab and was changing the dash to a wood grain version off of a limited. Other than some vent issues, the biggest problem is that the radio opening is smaller on the woodgrain dash than on the original black part. My radio is not the JBL model. Will the JBL model fix the issue and is it a plug and play? Thanks, Mike
    YardBird likes this.
  2. Dec 25, 2020 at 11:07 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  3. Dec 25, 2020 at 11:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm going to guess your wood grain came out of an older truck. The older (00-02) trucks had a smaller dash opening.
    An older stock radio or aftermarket radio would be the answer.
  4. Dec 25, 2020 at 11:21 AM
    2004tundrasr5oem
    I was told that it was out of an 03 limited.
  5. Dec 25, 2020 at 12:17 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    About the only way to check would be to search the part number if it's stamped on it.
    Or use it as an excuse to upgrade the radio to a double DIN unit.
  6. Dec 26, 2020 at 7:00 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  7. Dec 26, 2020 at 7:31 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You might want to post this question in our Audio section. There are quite a few knowledgeable people that might could help you.
  8. Dec 27, 2020 at 7:24 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
