Won’t start. Won’t turn over.
Discussion in 'Other Toyota Vehicles' started by jkcoop02, Feb 6, 2022.
  1. Feb 6, 2022 at 2:03 PM
    jkcoop02
    jkcoop02 [OP] New Member
    2015 Tundra
    My wife’s 2014 Sequoia Platinum won’t start. No clicking sounds either. Put my multi-meter on the battery. 12.47 when completely cold. Turn the key on and everything lights up. Can turn the AC on full and the headlights don’t dim. Swapped the relay from my Tundra with hers. Nothing. I’m guessing the starter. Any other ideas??
  2. Feb 6, 2022 at 2:05 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Probably starter as you already said.
    Grounds all kosher?
  3. Feb 6, 2022 at 2:08 PM
    timsp8
    NY
    I’ve read about issues with the key fob chip. Do you have a spare key you can try?
    14burrito likes this.
  4. Feb 6, 2022 at 2:24 PM
    jkcoop02
    2015 Tundra
    All appear to be good.
  5. Feb 6, 2022 at 2:25 PM
    jkcoop02
    2015 Tundra
    Yup. Using my spare key.
  6. Feb 6, 2022 at 3:59 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Visually inspect all fuses? Inside and in engine bay. Any remote starter installed?
  7. Feb 6, 2022 at 4:18 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Did you try jumping it (to quick test if starter engages this way)?
    2mchfun and RitcheyRch like this.
  8. Feb 6, 2022 at 4:23 PM
    jkcoop02
    2015 Tundra
    Looked at fuses for starting. There is remote starter from the factory. ?
  9. Feb 6, 2022 at 4:24 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is the instrument cluster displaying the appropriate P for park?
    Have you tried starting in neutral?
    2mchfun likes this.
  10. Feb 6, 2022 at 4:38 PM
    jkcoop02
    2015 Tundra
    No. Gonna push it out of the garage in the morning to see if my Tundra can jump it off.
    BrandonL812 likes this.
  11. Feb 6, 2022 at 4:45 PM
    jkcoop02
    2015 Tundra
    Yes. Shows to be in P. One of the first things I looked as I had an F-150 that had that issue once. And yes… tried starting while in neutral as well.
    Nothing.
    landphil[QUOTED] likes this.
  12. Feb 6, 2022 at 4:48 PM
    BrandonL812
    Brandon
    I’m wondering if the remote starter is preventing it from starting.
  13. Feb 6, 2022 at 4:51 PM
    jkcoop02
    2015 Tundra
    How can I check that? Can it be bypassed?
  14. Feb 6, 2022 at 5:36 PM
    BrandonL812
    Brandon
    You’ll have to locate where the starter module is located under the dash. See how it was installed, did they use a T harness or tap into factory wiring.
  15. Feb 6, 2022 at 6:59 PM
    2mchfun
    Use your meter to check for continuity from ground post on battery to engine block/chassis. That will confirm ground. You can place neg on engine block pos. on battery and check voltage to confirm. Also check for loose hot terminal. To starter. You might have rodent damages as well.
  16. Feb 6, 2022 at 8:33 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    A dead starter usually clicks or dims the headlights when cranking.
    I dont think you have ignition signal to the starter. Where to start looking for that, i dont know. An easy spot is probably a starter relay somewhere. Factory wiring diagrams are available on this forum.
  17. Mar 23, 2023 at 4:28 AM
    Evil666Joe
    Evil666Joe New Member
    Joe
    Fresno, CA
    '03 Tundra AC SR5 4.7 A/T
    Put a test light on the starter terminal & see if you have power when you turn the key. I had a starter that had a dead spot on the armature, it would stop on that spot & I'd have to move the armature to get it to work. Took a while to figure that one out.
  18. May 31, 2024 at 10:58 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Remove the starter relay and jump this b with a paperclip or flat head screwdrivers and rule out the starter... If you haven't already figured this out
