Wix Air Filters
Discussion in 'General Tundra Discussion' started by awhendricks, Mar 18, 2019.
  1. Mar 18, 2019 at 7:50 PM
    awhendricks
    awhendricks [OP] New Member
    Austin
    2017 Tundra Limited 4x4
    A7301EF7-C14B-4A0E-AA05-6920888FEDFC.jpg B43C15B7-A636-4537-9D89-90C9A40BF4A0.jpg I just put a new Wix air filter in my 2017 Tundra, and the filter had an extra pad attached to the bottom of the filter. When did Wix start doing this? Considering the stock one doesn’t have this, any reason I shouldn’t use this filter? Thanks in advance.
    georgiey22 likes this.
  2. Mar 18, 2019 at 8:01 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    No data to share but I like it!
  3. Mar 18, 2019 at 8:20 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wix makes great filters, I'd leave it on. I bet it filters air even better. I may get one next time I need a filter. Clean air is good, and for me even of it's a little more restrictive that's fine.
  4. Mar 18, 2019 at 8:30 PM
    Rockanock
    Rockanock 21 Chevy 2500
    I swear by WIX. Great filters. I ran K&N for a few years And had some issues from it. Went to WIX and had much better results. I have yet to replace filter in my Tundra since it’s still so new but will before summer
    Wallygator likes this.
  5. Mar 18, 2019 at 8:39 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Would leave as is.
  6. Mar 18, 2019 at 8:41 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Leave the pad on, that’s how they come- I believe it may be a moisture barrier. They’ve been like that for a long time, at least for the 4Runner. WIX makes great stuff- they’re what my garage uses.
    Wallygator and coldcanuk like this.
  7. Mar 6, 2023 at 4:49 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    I like it, more protection. That will be my next air filter .
    But doesn't the box have another filter pad built in to It that you can't replace?
  8. Mar 6, 2023 at 8:01 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Extra, extra filtering power.
    Yes, the filter box does have an additional 'post filter' if you will.
    This looks to add a pre-filter filter. Cool
  9. Mar 6, 2023 at 8:05 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    My WIX filter has the same stuff on it. No issues for the last 2 years, I believe it's just a pre-filter.
  10. Mar 6, 2023 at 9:55 PM
    Dalandshark
    Dalandshark Fortified with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    I agree nothing wrong with it. Just remember more filter = less airflow. Might need to change more often. Or, may be able to vacuum it off easier. Who knows.
  11. Mar 7, 2023 at 1:40 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    With my engine element by Wix, whose air and oil filters I also swear by, my 5.7 whines a bit at takeoff when it's subzero temps. It's been isolated to a certain gasket that has a plastic screen in it unique to Tundras 5.7's that isn't there in the Sequoia, and it makes me think of going back to stock air filters. But not yet, only been 10k miles.
  12. Mar 7, 2023 at 3:04 AM
    Wallygator
    Wix is the air filter of choice here. They make filters for a few brands.
    I believe Denso makes the Toyota OEM filters so if you want to stay stock and save money, buy the Denso filter. Rock Auto carries them. Or at least they did.
