Wiring Light bar onto existing fog light switch
Discussion in 'Lighting' started by sta_f0u, May 19, 2020.
  1. May 19, 2020 at 4:32 AM
    sta_f0u
    sta_f0u [OP] New Member
    Jon
    Nevada
    2017 White Tundra Limited 4x4
    New owner here!
    So I have seen a few post online and even on this forum, but have not found an answer or a guide on if it's possible or has been done.
    I have a 2017 Tundra Limited. I've purchased a new front bumper. The new bumper will not have fog lights but will have a light bar that i've purchased with it.
    My goal is to hopefully just have the existing fog light switch (a turn dial next to the headlight) to activate the light bar. I'm sure if I'm using the existing switch, that the same rules with the current fog lights will be in effect ex: Can't use lightbar with high beams on. Which is fine.
    Is there a way I can make this happen. I've learned a bit about relays and they make sense, just want to know if there's a way I can run the existing fog light switch to the relay, and if so where can I find that switch wiring and how to wire it to the relay.
    Thank you for your time!
  2. May 19, 2020 at 4:57 AM
    sta_f0u
    Jon
    Nevada
    Awesome I will take that information and learn from it. Your gif explains my reaction perfectly. Thank you!
    NewImprovedRon likes this.
  3. May 19, 2020 at 5:10 AM
    sta_f0u
    Jon
    Nevada
    I'm excited about it! Just purchased the truck 2 weeks ago and I've already purchased a few mods and the list just gets longer. I'm very thankful for the help and hopefully one day I'll be able to pass on the knowledge down the line.
  4. May 19, 2020 at 7:21 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    That's exactly how I did mine, I snagged the trigger wire for the relay straight from the 12 volt wire going to the fog light. Everything was on the engine firewall side. No need to wire anything inside the cab. Just simply turn on the fog lights.. Good luck, I'm sure it will turn out great.
  5. May 19, 2020 at 12:38 PM
    sta_f0u
    Jon
    Nevada
    Were you able to find a way to bypass the high beams from turning off the light bar? I'm a Nevada native as well. Clark County!
  6. May 19, 2020 at 12:58 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    No, I never bypassed it. The light bar would turn on using the fog light switch in regular mode only.
  7. May 24, 2020 at 10:51 AM
    Wintersun
    Wintersun New Member
    The reason that fog lamps are mounted as low as practical is to minimize glare and a light bar works best in my own experience when it is mounted as high and as far back as possible (front edge of a truck cap has worked the best for me).
    With different lights it is a good idea to have separate switches so you can decide which to turn on and which to leave off depending upon the situation.
  8. May 24, 2020 at 11:46 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Go to the lighting section and do a search. A lot Tacoma owners have modified the relay to accomplish this. Not sure if the Tundra fix is the same. I have seen posts on this here.
  9. May 25, 2020 at 9:10 PM
    sta_f0u
    Jon
    Nevada
    The bumper I'll be installing has a lightbar slot so just filling that in and I agreee with the own switch logic. I think I am going to end up wiring it to its own switch and just remove the fogs for now and when the time (money) is right I'll buy fogs and connect those to the existing fog switch.
  10. May 26, 2020 at 8:59 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Here you go. I did this with my light bar to my high beams. Only difference is you want it to be activated with your fog lamps. In theory, you can replace where 85/86 tap into and as long as it is a 12v source, it will activate your new light. Hope this makes sense. All you would need to get is a relay, wiring terminals, Wire, inline fuse. The Orange circles are wiring connections if that makes sense. Make sure your inline fuse is as close to the battery as possible. About 12" is about right.Fuse size will be dictated by your light bar. LMK if you have any other questions.
    If you want to change your factory fog circuit so it doesn't turn off when you use your high beams, I used FogLightEddiev1 and it worked on my 2016. https://www.tundras.com/threads/diy-fog-light-mod.371/
  11. Jun 11, 2020 at 3:36 AM
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
