Wiper cowl/Windshield seal coming loose...
Discussion in '2.5 Gen Builds (2014-2021)' started by ttc06, May 5, 2018.
  1. May 5, 2018 at 5:23 PM
    ttc06
    ttc06 [OP] New Member
    Missouri
    2016 Tundra SR5 TRD Package
    looking to see if any of you have had this issue with your truck. I went through a car wash the other day and noticed the weather stripping at the bottom of my windshield was starting to come loose. took it to dealer and they said it looks like i hit it with an ice scraper (i did not) and that they wont fix it. the stripping is part of a larger wiper component cowl piece and it is $580!!!. have any of you had this issue and had it replaced under warranty. im going to escalate this with the dealer obviously .
    RJB954 likes this.
  2. May 5, 2018 at 5:47 PM
    15whtrd
    15whtrd Mr. Blonde
    I was putting some waxaddict on my cowl and pushed on that rubber seal too hard. It can be snapped back into place, it’s just a little tricky to do it.
    NewImprovedRon likes this.
  3. May 11, 2018 at 4:28 PM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Mine is the same too today was putting 303 and I think I push down too hard. Try to snap it back but the seal doesn’t lay flat to the windshield. Help please. :)
  4. May 11, 2018 at 4:34 PM
    15whtrd
    15whtrd Mr. Blonde
    I pushed mine accidentally and it rolled underneath itself. I took a plastic putty knife and coerced it back out of its hole LOL.
  5. May 11, 2018 at 4:35 PM
    ttc06
    Missouri
    yeah it's pretty much ruined once it gets pushed down and separated. This should be a recall item in my opinion. Good news is that i go in to have mine replaced under warranty tomorrow. All i had to do was raise the issue that this seems to be a very common problem and insinuate some bad reviews online.
  6. May 11, 2018 at 4:36 PM
    ttc06
    Missouri
    don't really make a big point of saying you pushed it in. tell them you took it to a car wash and it shoved it down. thats what happened to mine
  7. May 11, 2018 at 4:42 PM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    I have a 2015, don’t know if it’s still under warranty.
  8. May 11, 2018 at 4:50 PM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Cool..gonna take it to the dealer and see if they will fix it under warranty
  9. May 11, 2018 at 5:47 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine wasn’t ruined, it’s perfect once I put it back in place.
  10. May 11, 2018 at 5:57 PM
    TheBeast The Beach
    mine was the same. you can push it back in and it will be like new
  11. Oct 8, 2019 at 5:02 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    Just noticed mine is doing the same thing.
  12. Oct 8, 2019 at 5:40 PM
    Raidercat
    Raidercat New Member
    2019 Tundra 1794
    I just bought my truck two weeks ago, noticed a couple days after buying that this part had separated from almost half the cowling. I was able to push it back in after a couple of tries and it went back, no issues since. This is a 2019 truck so seems to be an issue.
  13. Oct 8, 2019 at 6:17 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    Mine was like that when I bought the truck and I pushed it back in place by hand. However, yours looks a little deformed. If it is they should warranty it.
  14. Oct 9, 2019 at 4:58 AM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    Reported this similar issue about the cowl seal. Toyota inspected and will be replaced today at cost with Toyota warranty.
    Rex Kramer likes this.
  15. Oct 10, 2019 at 5:32 AM
    purplenova
    Tom
    Ohio
    Took mine in to the dealership and the quote is $622.50. Said the trim piece is part of the cowl panel (55708-0c061) but in the part diagram it
    shows two different items. I have the extended warranty out to 100k but the dealership did not see that info in my account and said it wasnt covered. Spoke to the warranty company and they say otherwise. So its back to the dealership I go.
  16. Oct 22, 2019 at 8:01 AM
    purplenova
    Tom
    Ohio
    Follow-up on my Oct 10th post.
    Not covered under any warranty 3/36 or Certified. Im 6 months outside my 3/36
    and the extended wont cover it because its "a trim piece" so they say. Even though
    that small trim piece is part of the cowl panel.
    Contacted Toyota corp and they will reimburse me $200.00, all I need is copy of the work order
    and receipt showing payment.
    My question is: what function does that small rubber trim piece serve? And if I choose to not
    replace it, what will that cause down the road.
    @Roman - is the small trim piece available separately from the cowl piece (55708-0c061)
  17. Oct 22, 2019 at 8:49 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  18. Oct 22, 2019 at 8:53 AM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    Just curious why the cowl was very expensive. Could be the whole assembly or labor? The cowl on my tundra was recently replaced. It is under warranty and I noticed it was just the cowl that was replaced.
  19. Oct 22, 2019 at 9:10 AM
    purplenova
    Tom
    Ohio
    $444.00 for the part and $178.50 install is what the dealership quoted.
    I even asked them, if the small trim piece was available and they said no - lol
  20. Oct 22, 2019 at 9:12 AM
    purplenova
    Tom
    Ohio
  21. Oct 22, 2019 at 9:31 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t know what yours looks like, but mine got pushed down in when I was a little aggressive drying the windshield off. I was able to re-position the rubber with a plastic putty knife.
  22. Oct 22, 2019 at 10:09 AM
    Roman
    Roman
    Franklin, TN
    No, the rubber strip I linked to is on the bottom side of the cowl where the hood closes against it, not the one on the windshield side. If you need the one on the windshield side, it does come with the cowl.
  23. Oct 22, 2019 at 10:15 AM
    purplenova
    Tom
    Ohio
    I was told by the service guy at my dealership that the small rubber trim piece is part of the cowl. I hoped it was available separately, but I guess not.
    Thanks for your time @Roman
    Roman[QUOTED] likes this.
  24. Oct 22, 2019 at 10:17 AM
    purplenova
    Tom
    Ohio
    Mine isnt too bad. It was also pushed down so I gently pulled it out and now its all wavy.
    my concern is, if I dont have it repaired properly it might cause other expensive issues down the road.
    15whtrd[QUOTED] likes this.
  25. Oct 22, 2019 at 10:19 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t think it’s gonna hurt anything at all. It’s probably more of a rubber cushion between the cowl and the windshield. It’s not a perfect seal by any means.
  26. Oct 22, 2019 at 10:23 AM
    War Machine
    War Machine SSEM # 5 3MW
    Same here. I actually did it when I was doing my Solution Finish / Black Wow review. I finagled it back in place. I was considering running a bead of silicone across it.
  27. Oct 22, 2019 at 10:30 AM
    purplenova
    Tom
    Ohio
    I may not even worry about it then. Toyota is still giving me $200.00 for whatever I choose, so I may just use that $$ elsewhere.. LOL
  28. Oct 23, 2019 at 10:53 AM
    purplenova
    Tom
    Ohio
    Video of 2007 Tundra Wiper Arm Removal and the cowl panel.
    I would assume its the same for a 2016.
    https://youtu.be/JNpvwMZfD8c
    I may take it off and see if I cant attempt a fix for the small trim piece.
  29. Dec 11, 2019 at 2:28 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I looked at mine today whilr wiping windshield and noticed the cowl/strip is warped and not sitting flush against the windshield in several areas. Anyone else have this issue? Is this a problem and cause to have dealer repair or just let it be and roll on?
  30. Dec 11, 2019 at 2:36 PM
    purplenova
    Tom
    Ohio
    I have same issue. That small piece is part of the entire cowl panel and it's expensive. If your truck is still in warranty, they should cover it, if not it will cost you. Mine is 6 months out of warranty and my certified warranty wont cover either because it's a "trim piece"
