Winter Tire Pressure
Discussion in 'Wheels & Tires' started by TundraLuv, Nov 7, 2018.
  1. Nov 7, 2018 at 11:16 AM
    TundraLuv
    TundraLuv [OP] New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    I know you can look in the door jam and see what the factory suggested tire pressures are. But, I was curious to see what folks run on the tundras in the winter. Live in the midwest so it gets pretty cold.
  2. Nov 7, 2018 at 1:06 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I usually run 5 above door sticker
  3. Nov 7, 2018 at 1:24 PM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    On a cooler day, i air them up to 36psi. Or as most members will say, use the chalk test. Haven't tried it myself though..
  4. Nov 7, 2018 at 1:50 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Assuming winter as in cold rain/ice/snow, I’m leaving mine so they underinflate a bit, unless the roads are clear, then I’ll make sure they’re at what Nitto says, 42.
  5. Nov 7, 2018 at 1:59 PM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    According to the ideal gas law, as all New England Patriots fans can tell you, PV = nRT, as the temperature drops so does the pressure of the gas (in this case air) in the volume of your tire. Air pressure in a tire typically goes down 1-2 pounds for every 10 degrees of decreased ambient temperature.
  6. Nov 8, 2018 at 3:03 AM
    Adam New Member
    My god. It is a good thing my 14 doesn't have the option to look at the pressures. My OCD wouldn't allow that 29 when the other front tire is at 32
    TundraLuv[OP] likes this.
  7. Nov 14, 2018 at 3:40 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    Mine is the same way. If you want to go completely insane, drive around with the tire pressures displayed. They will change as you drive. Mine are all always within 1 or 2 PSI of eachother, I've learned just not to look anymore. With temperatures now being below freezing, my pressures are set at about 30. But I've seen 29 upon start up, and they can go up to 31 after some time driving.
    OR18TRD[QUOTED] likes this.
  8. Nov 14, 2018 at 4:22 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Wait for a cold night, truck outside, morning time inflate to door jam or preference, reset TPMS and your done. Cold tire reset.
  9. Nov 14, 2018 at 5:41 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Mine dropped quite a bit.. filled them up in the morning when it was about 28 degrees.. should be good now
    14burrito likes this.
  10. Nov 14, 2018 at 5:44 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    what's the chalk test?
  11. Nov 14, 2018 at 6:31 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    This is it... “or is it?”
  12. Nov 14, 2018 at 6:36 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Neat, but those two about got on my nerve...
    JoshuaA likes this.
  13. Nov 14, 2018 at 6:39 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    If you do the chalk test, your pressure shouldn't change for winter. If anything, the chalk test is more relevant in winter since it helps you get the most contact patch to the road. So if you live in an area with water and snow, more contact patch means better traction.
    gm125800 and JoshuaA like this.
