Wind noise issue
Discussion in '1st Gen Tundras (2000-2006)' started by Toyoda Tundra, Dec 20, 2020.
  1. Dec 20, 2020 at 8:04 PM
    Toyoda Tundra
    Toyoda Tundra [OP] Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    2004 Toyota Tundra Access cab. Every time I drive on the highway I hear a loud wind noise, it’s pretty loud to the point where I have to turn up my music pretty high in order to hear it. The wind noise seems to be louder in the middle inside the cabin. has anyone experience this? Any ideas/solutions?
  2. Dec 20, 2020 at 8:16 PM
    Toyoda Tundra
    I forgot to mention that I tried putting tape on the windshield trim to see if I stopped hearing it but no luck.
  3. Dec 20, 2020 at 8:20 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    Some suggestions I’ve seen are to check/clean the weatherstripping around your doors.
    Tuck some backer rod between dash and windshield.
    Install Dynamat/Noico/Hushmat type product.
    Do you have the rain guards on windows? Those add noise.
    Is the whine more of an electrical/mechanical type thing or are you certain it’s wind?
    What kind of tires are you running?
  4. Dec 20, 2020 at 8:28 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Could very well be the steering shaft seal. There's a thread about it here somewhere.
    jpink and Toyoda Tundra[OP] like this.
  5. Dec 20, 2020 at 8:28 PM
    Toyoda Tundra
    Thank you @jpink, I’m pretty sure it’s wind, it seems to be louder on the middle of the cabin. I do not have the window rain guards and I’m running regular all season tires.
    Tundra2 likes this.
  6. Dec 20, 2020 at 8:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Dec 20, 2020 at 9:56 PM
    Toyoda Tundra
    Thank you @Tundra2, I will look into it. If anyone has any other suggestions lmk.
    Tundra2 likes this.
  8. Dec 20, 2020 at 10:15 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    For what s it s worth I ve owned a few cadillacs, and Lincolns, and the thing I found in common was an underlayment. I think it was tar based. It was placed in the floor, and the firewall of the vehicle. If you ve rode in these types of vehicles you ve probably noticed the quietness. There s something to be said about this approach.
    Toyoda Tundra[OP] likes this.
  9. Dec 21, 2020 at 4:10 AM
    Professional Hand Model
    Hand Protectors
    Yeah.
  10. Dec 21, 2020 at 6:21 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Has the windshield been replaced recently? If the truck is new to you has it done this since you got it or is this something new?
    When I picked up my truck (years back) they just put a new windshield in and the wind noise was bad; pushing out on the windshield made a lot of the noise go away.
    I wound up replacing the windshield again and it fixed the problem.
    Just a thought...
  11. Dec 21, 2020 at 10:34 PM
    Toyoda Tundra
    I have never replaced the windshield. It seems to have gotten worse, it wasn’t bad when I first got the truck. I will look into all y’all suggestions. Thank you everyone!
    trueblue1981 and Tundra2 like this.
  12. Dec 21, 2020 at 10:39 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  13. Dec 22, 2020 at 3:36 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Does your sunroof seal properly?
    Tundra2 likes this.
  14. Dec 22, 2020 at 3:53 PM
    Toyoda Tundra
    No sunroof.
  15. Dec 22, 2020 at 3:57 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    OK, any tears in door weatherstrips or missing pieces? When I was cleaning the bottom of RR door in mine, I had the splash shield off and could hear it when driving around, but I knew what it was.
  16. Jan 6, 2021 at 12:30 AM
    Toyoda Tundra
    The weatherstripping is looking rough, I will start with that once I get the chance. Thank you all for the suggestions!
  17. Jan 6, 2021 at 2:56 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I had the same issue turned out it was the windshield seal at the bottom so it really couldn't be seen.
    I didn't find it until water started blowing onto the dash during a highway trip.
  18. Jan 27, 2021 at 2:01 PM
    Toyoda Tundra
    Hello, I’m just now getting a break so I can work on my wind noise issue. What exactly did you do to fix yours?
    MXPCUS likes this.
  19. Jan 27, 2021 at 2:01 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I just had Safelite put new glass in it since it was cracked anyway.
  20. Mar 21, 2022 at 1:42 AM
    Off Tarmac
    Off Tarmac Semi-Amateur Mechanic
    Boulder County, ColoRADo
    2002 Thunder Gray Metallic Tundra TRD
    Bilstein 5100’s with leveling lift, 2021 Tacoma TRD Rims, JDM interior/exterior LED’s, Nakamichi Apple CarPlay receiver, Alpine speakers, Access Tonneau Cover, KSP 1 1/4” wheel spacers, Borla exhaust, Line-X spray-on bed liner, WeatherTech floor mats and bug shield.
    Did windshield replacement fix your wind noise issue? I just had my windshield replaced a few weeks’ back and it seems much more noticeable on the highway.
  21. Mar 21, 2022 at 3:32 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    In my case yes, there's still noise but most of that seems to be from the sunroof.
  22. Mar 21, 2022 at 5:58 AM
    shifty` Our private little trip to hell
    Zombie thread.
    My windshield guy warned me about our trucks and their roof rail covers. Specifically, he mentioned by the time our trucks get to their age, the adhesive used to hold them down is on its way out. He'd had several customers complain about wind noise, and many times it's because air is either getting under the rail covers, or the adhesive in the front has come up and they're flapping around at highway speed.
    I hadn't It's not really safe for you to check that yourself, so instead, try this: Take some painter's tape or packing tape , tape both channels from the windshield to the rear window. Go for a drive and see if it's still there. You can use this tape trick in all areas of the truck to check if the noise goes away after taping an area. You may also try the side channels of the windshield, the top seal of the window, etc. But the fact you just had the windshield replaced, after what dude who's been doing this for decades says, I'd suspect the roof or windshield seals first if this came right after a windshield repair.
    Toyoda Tundra[OP] and Festerw like this.
  23. Mar 21, 2022 at 8:56 PM
    Toyoda Tundra
    . I still haven’t fixed mine, been very busy with school but I believe I figured out the issue, my windshield upper molding/trim is not properly sealed, windshield is not original was replaced by previous owner. Unfortunately I can’t just replace the molding, it looks like it’s glued on there, most likely will have to have windshield re-sealed.
    2005tundra_nopayments likes this.
  24. Mar 22, 2022 at 6:17 AM
    Easy way to confirm is to tape across the entire top of the windshield. If you're worried it'll look goofy, use clear packing tape. I prefer frog tape or blue tape because it won't leave residue, but ... quick and easy test for leaks and noise.
  25. Mar 22, 2022 at 6:28 AM
    Toyoda Tundra
    That’s how I was able to confirm a while back. I appreciate the feed back
    shifty`[QUOTED] likes this.
  26. Mar 22, 2022 at 6:40 AM
    Gotcha. I admit, I failed to read earlier in the thread. But then I did and got confused seeing this:
  27. Mar 22, 2022 at 6:48 AM
    Toyoda Tundra
    Using a different type tape was the difference. When I first tried it I used electrical tape, got some silicone tape and that worked a lot better.
  28. Mar 22, 2022 at 6:51 AM
    Ah! That's good info. I prefer the clear Duck brand packing tape for finding roof/window leaks. It's clear, smooth, and you can leave it on for extended periods without it being totally obvious. Sometimes it leaves residue if you let it bake on, but Goo Gone makes easy work of that. I'd never even heard of silicone tape before today, I've seen it used before, but never knew what it was called! (learned something new)
