Will it fit? 285/75/18
Discussion in 'Wheels & Tires' started by jfung12, Jan 10, 2018.
  1. Jan 10, 2018 at 4:03 PM
    jfung12
    jfung12 [OP] New Member
    Washington
    2016 Tundra CM
    TRD Sway Bar 3/2 Readylift Volant Intake WInjet LED taillights Hidden Bumper LED Bar
    I got a 3/2 lift and going to have +20 offset wheel Will a 285/75/18 fit with no further mods?
  2. Jan 10, 2018 at 4:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No. You will definitely have to remove your mudflaps. Will definitely rub the front plastic. And there's a good chance you'll need a CMC.
    zcarpenter92, 831Tun and Marty McFly like this.
  3. Jan 10, 2018 at 4:12 PM
    jfung12
    Washington
    2016 Tundra CM
    @joonbug not worried about that small front flap but i would like to keep the one behind the front tire. New to this whats a CMC
  4. Jan 10, 2018 at 4:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No, the rear mudflap will definitely have to come off. CMC is a cab mount chop. It's the metal part behind the mudflap that sticks out. They will grind that part off and weld on a metal plate to create more room for your tire when it's fully locked. You may not need the CMC, depending which tire you go with, but you're going to be awfully close.
    831Tun likes this.
  5. Jan 10, 2018 at 4:20 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  6. Jan 10, 2018 at 4:21 PM
    jfung12
    Washington
    2016 Tundra CM
    285 75 toyo
  7. Jan 10, 2018 at 4:26 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's really close to 35" if I remember correctly and about 12" wide. Kinda depends on how much caster your alignment shop puts in there but I'd plan on the CMC like Joon said. It's really not a big deal. I didn't want to do it but my tires said I had to.
    joonbug likes this.
  8. Jan 10, 2018 at 4:29 PM
    jfung12
    Washington
    2016 Tundra CM
    yeah a 34.8 by 11.2
    zcarpenter92 likes this.
  9. Jan 10, 2018 at 4:32 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Narrower than I thought. I've been thinking 'bout running that size next time. My front is lifted about 3.5", I've done the CMC and have a +28 offset. The lower that offset number goes, the closer the corner of the tire gets to the cab mount.
    joonbug and jfung12[QUOTED][OP] like this.
  10. Jan 10, 2018 at 4:36 PM
    jfung12
    Washington
    2016 Tundra CM
    I may have to hold off on those tires then because i dont want to get the chop XD
  11. Jan 10, 2018 at 4:57 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I think you might be good. I run the same size and my truck is just leveled out. I don’t have any rub, but it is a pretty tight in there... I bought it with this set up.
    FC44141A-9396-4971-A41E-E2A25F064D02.jpg D3C8B385-954C-440F-891F-F6549CF3B33A.jpg AC0E3AF5-BAAB-4644-823D-FD67499ABA61.jpg
    Zero One Actual likes this.
  12. Jan 10, 2018 at 5:01 PM
    jfung12
    Washington
    2016 Tundra CM
    do you know your offset? @BHarry
  13. Jan 10, 2018 at 5:16 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    Sorry, I don’t but they don’t stick out too far...:notsure:
    3131A1A5-76FA-4D85-B410-D8BF2B8FBC40.jpg 4579A42D-0DA9-4327-BD0D-041F169482FF.jpg
  14. Jan 10, 2018 at 5:34 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Dude, a CMC isn’t a worry. If you have a welder and something to cut it with you can do it yourself. I didn’t have to do a CMC but was fully prepared to do it if needed.
    Almost looks like a +12, same offset as i’m Running.
    joonbug likes this.
  15. Jan 10, 2018 at 6:12 PM
    jfung12
    Washington
    2016 Tundra CM
    would a 295 70 18 be the best option?
  16. Jan 10, 2018 at 7:04 PM
    Zero One Actual
    I plan on running this size on some SCS Ray 10s on the Bilstein 6110 on the top setting and 5160s in the rear with an add a leaf or CB shackle to level it.
