Will I have any issues towing 4200lbs on a long trip?
Discussion in 'Towing & Hauling' started by kameleon, Jun 6, 2018.
  1. Jun 6, 2018 at 5:43 PM
    kameleon
    kameleon [OP] New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    Hi all. I am looking at getting a tundra but have a quick question that will help me decide on which one to look for. I am looking for a 05/06 double cab 2wd with the 4.7L and factory tow package. My main concern is should this truck be able to tow a car on 16ft trailer (about 4200lb total, trailer and car) on a 2500 mile trip without too much issue? I would be coming from down south up to around the New Jersey area and back (hills are definitely going to be encountered). As long as normal maintenance is done should I be good to go?
  2. Jun 6, 2018 at 5:57 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Consult your vehicle manual in the glove box. Internet search it if not. There are towing senarios in the manual with weights etc that will help you.
  3. Jun 6, 2018 at 7:04 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    No
    BestGen likes this.
  4. Jun 6, 2018 at 7:09 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I drove an 1800 mile road trip in my tacoma (4.0) with 600+ pounds in the bed towing ~3200 lb trailer. You should be good.
    JoshuaA and kameleon [OP] like this.
  5. Jun 6, 2018 at 7:10 PM
    kameleon
    Jackson, MS
    Yeah, I am not sure the truck I have in mind has the manual but I can see. I know the truck can tow up to 5000lb and this is not at that upper limit, and will actually be less if my maths are right. That is why I was asking for some knowledge from the board and maybe someone has tried it before and could share some knowledge.
    Any particular reason why not?
    I am debating between an 05/06 and the 07+ double cab w/ 5.7. I know the 07+ will easily do it but it is almost out of my price range unless I get one with half a million miles on it.
    BTBAKER likes this.
  6. Jun 6, 2018 at 7:13 PM
    kameleon
    Jackson, MS
    Thanks for the firsthand experience. What year taco if I may ask?
    If my maths are right the car will be around 2100lb and the trailer is like 1700lb. So roughly 3800lb total trailer. Either way I go I will make sure the transmission is up to snuff and the engine has had regular maintenance.
  7. Jun 6, 2018 at 7:27 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    It was an 08 Tacoma. I also used to have an 03 tundra 4.7 great truck @ 185k miles. All in all it’s a Toyota and I wouldn’t worry too much.
  8. Jun 6, 2018 at 8:08 PM
    kameleon
    Jackson, MS
    Sorry, I misread this I thought you were saying I would not be able to tow it. But in fact you were saying I shouldn't have issues.
    Cement Pro and Bob like this.
  9. Jun 6, 2018 at 8:26 PM
    JoshuaA
    JoshuaA Perpetual Modulator
    Southern Ontario
    Should be no problem, not sure how much tongue weight you'll have, I'd get Air Bags if the rear sags. It'll keep your nose down, steering planted and you won't purpoise over bumps.
  10. Jun 6, 2018 at 8:32 PM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    Airbags just put more weight on the rear of the truck, a weight distribution hitch is the proper way to correct a sagging rear end while towing.
    Jengel451, Pudge and ColoradoTJ like this.
  11. Jun 6, 2018 at 8:48 PM
    JoshuaA
    Southern Ontario
    True, using a WDH is a given, I wouldn't tow without one and have a Blue Ox, but it won't correct additional sag and nose bobbing over potholes/bumps. Not a nice feeling before I added Timbrens (Air Bags are more comfortable for long distances).
    Wintyfresh likes this.
  12. Jun 6, 2018 at 8:54 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    You're more likely to have trouble with the trailer than the truck. Does the trailer have brakes?
  13. Jun 6, 2018 at 9:04 PM
    kameleon
    Jackson, MS
    It will. Neither truck nor trailer has been purchased yet. The trip is still a few months away so I'm doing all my homework first.
    Definitely looking at weight distribution hitch and possibly rear airbags. I had a '00 4runner and the bags helped tons!
    ColoradoTJ and JoshuaA like this.
  14. Jun 6, 2018 at 9:08 PM
    Baja Mike
    South Bay, Ca.
    Get some stabilizers/sway controlers for it and you'll be good.
  15. Jun 6, 2018 at 9:20 PM
    kameleon
    Jackson, MS
    Thanks for all the input yall. It has really put my mind at ease on this. Can't wait to get my tundra!
    ColoradoTJ and trayday like this.
  16. Jun 6, 2018 at 9:52 PM
    Jason808
    Jason808 "Thrust you can Trust"
    2012 Platinum crewmax
    You'll be fine. We tow our camper(4650 lbs dry) no problem with our 06 crew cab 4.7. And we're in Colorado and go over the passes a lot. Truck is all stock besides a brake controller and a WDH.
    ColoradoTJ and Wintyfresh like this.
  17. Jun 7, 2018 at 5:22 AM
    Cement Pro
    Stock
    Just use the tow haul mode. If the truck squats to much consider a weight distribution hitch. Anything heavy you put in the bed with the trailer attached will make it squat more. Like already mentioned, make sure the trailer is in good working order.
  18. Jul 7, 2018 at 2:23 AM
    RobinTinsley
    RobinTinsley New Member
    Robin
    If you are still in confusion and have towing issues, then either you can check vehicle manual or else you can consult Florida Transporter who can explain you in detail and can help you in clearing all your issues regarding towing a car. Moreover, you can hire their service too if you need hauling or towing service in future.
  19. Jul 7, 2018 at 5:08 AM
    ColoradoTJ Professional cat herding expert. Staff Member
    White GMundra
    Fuzzy Mirror Dice
    What kind of car? 2100 lbs is pretty light. Average at trailer depending on load rating is ~2k lbs.
    The truck your looking for will pull that load with ease. Get a good Load Distribution Hitch that you can back up without unhooking.
    Since you haven’t purchased the Tundra yet, I would really consider a 05-06. Better brakes.
    Trailers, just make sure axles are not bent, bearings and brakes are in good shape. A 7k lbs rated trailer is the most overloaded trailer I see around here. If you purchase a trailer from a private party, gave the trailer checked out by a retail trailer sales/repair shop. This can save you hundreds.
  20. Jul 7, 2018 at 5:30 AM
    Ericsopa
    Ericsopa Old man and the sea
    2013 Tundra CrewMax TRD Limited Super Duper White
    Only issue you'll have is finding gas stations along the way. Expect to refill at 250 miles max.
    Also make sure you leave plenty of room between you and anything in front of you. Your truck only weighs about 500 pounds more than your tow load. Braking will be your main concern.
  21. Jul 7, 2018 at 5:34 AM
    kameleon
    Jackson, MS
    The car is a 1985 Toyota MR2. Already light but I put an engine swap in it that is 100lb lighter than stock plus lighter 2000+ MR-s wheels.
    I am actually going to pick up a tundra today if all goes well. Found a nice 2012 double cab that I think will do nicely! I will update once I know for certain.
    ColoradoTJ likes this.
  22. Jul 7, 2018 at 5:46 AM
    White GMundra
    Fuzzy Mirror Dice
    An MR2 is that light!! Bad ass cars. I used to drive around a turbo model. Damn it was a blast.
    Good luck on the 2nd gen Tundra. That will be a better workhorse for you.
  23. Jul 7, 2018 at 5:49 AM
    kameleon
    Jackson, MS
    Yeah I think the curb weight on the 85 was like 2300 or something. I've had many MR2's. Even had 2 91' turbos. The white one was especially crazy as I imported a Gen4 3sgte and put it in there before it was "a thing". lol
    Thanks! I really hope this goes well and I have a new (to me) member of the family tonight.
  24. Jul 7, 2018 at 6:09 AM
    White GMundra
    Fuzzy Mirror Dice
    Most important thing I forgot to mention when you purchase the truck....
    Pics:thumbsup:
  25. Jul 8, 2018 at 6:27 AM
    kameleon
    Jackson, MS
    Mission accomplished! Picked up my 2012 TSS double cab yesterday.
