Wifes 4runner
Discussion in 'Other Toyota Vehicles' started by pbryant44, Feb 26, 2018.
  1. Feb 26, 2018 at 12:12 PM
    pbryant44
    pbryant44 [OP] New Member
    Panama city florida
    2016 tundra 4wd sr5 tss
    So I got in the wifes 4runner sunday and i realized that i might have been a little rough on it on the move here and so on. Its idling rough as hell im pretty sure something in the vehicle is broken. It has less than 4000 miles on it and we bought in in November. So when it goes in for the oil change i'm just going to tell them to find and fix the issue.
    Thegr8punkin likes this.
  2. Feb 26, 2018 at 12:36 PM
    Quebec
    Quebec New Member
    Owner's Manual, Page 155 - "Breaking in your new Toyota"
    "To extend the life of the vehicle, observing the following precautions is recommended:
    For the first 200 miles - Avoid sudden stops.
    For the first 500 miles - Do not tow a trailer
    For the first 1000 miles - Do not drive at extremely high speeds
    Avoid sudden acceleration
    Do not drive continuously in the low gears
    Do not drive at a constant speed for extended periods"
    Black Wolf likes this.
  3. Feb 26, 2018 at 12:39 PM
    pbryant44
    Panama city florida
    It had just under 3000 miles when we left so it was after the break in period.
  4. Feb 26, 2018 at 1:39 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    If you broke something it was going t break anyway......
    Good thing it is under warranty :)
  5. Feb 26, 2018 at 3:28 PM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Any check engine lights or anything? I've heard of rodent issues where they will chew up some wiring and cause the engine to go into limp mode, and it will run like shit.
  6. Feb 26, 2018 at 5:31 PM
    pbryant44
    Panama city florida
    No engine lights thats why im not worried about driving it more so it will trigger one hopefully.
  7. Feb 26, 2018 at 5:47 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Where was the move from and to? Is there a drastic change in weather or altitude? Try disconnecting the battery and see if it gets any better.
  8. Apr 17, 2018 at 7:12 PM
    Jackson
    Jackson New Member
    Theron
    WY
    2001 Black Tundra SR5 AC
    Sorry to jump in on another's post, but my 01 tundra had an ABS light come on, and so I disconnected the battery for a while to see if it would clear the light and now it runs like crap! Can't even climb a slight driveway. Don't know what I did but this this pickup has ran great until now... but it definitely cleared the ABS code and the check engine light is not on for me to read any codes.
  9. Apr 17, 2018 at 8:41 PM
    Sunnier
    Sunny
    San Diego, CA
    1.It's pretty much always okay to jump on another thread with a similar problem or question.
    2.I don't know what to suggest as the cause of your truck's performance problem. I DO suggest you start a new thread though-- because even though your post is "on topic" with the discussion on the thread, the title of this thread gives no hint about the real topic, so unless someone happens in here (I have a 4 Runner, so I looked), there'd be no one to look BECAUSE they have suggestions to help you. Anyway, good luck finding a fix!
  10. Apr 17, 2018 at 9:21 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Tey cleaning out the throttle body. Take a paper towel and spray carb clean or brake clean on the towel (DO NOT SPRAY IT DOWN THE THROTTLE BODY!!!!) push the butterfly valve open and wipe around where the tb meets the butterfly really well.
    Sunnier and Jackson[QUOTED] like this.
  11. Apr 17, 2018 at 9:23 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    this is your best bet at the moment. Other then that I wouldn’t screw with it at risk of voiding the warranty
  12. Apr 18, 2018 at 10:46 AM
    Jackson
    Jackson New Member
    Theron
    WY
    Thanks Connor! I am atop Parachute, CO but going to see if I can mooch some help from the guys that go down the mountain daily to bring me some carb cleaner. I am really hoping this is what it takes because it's def in limp mode. I will let you know if it works.
    Thegr8punkin[QUOTED] and Sunnier like this.
  13. Apr 18, 2018 at 9:35 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I wish you the best!
    Also, if you plan on hanging around on the forum a decent amount, there are a ton of guys and companies located Colorado. We normally try and get together at least once a year, usually at toytec’s coustomer Appreciation day and we try for a bit more.
    Here is the a good thread to go say what’s up In
    https://www.tundras.com/threads/colorado-bs-thread.39/page-80
    Here is the 2018 toytec customer appreciation thread. (And you don’t have to be a customer persay, it’s more like a big truck show with food and you can see some of the products the toytec sells for your truck, they aren’t a lot of 1st gens that come around but I know most people get a slight stiffy seeing 1st gens. Ain’t that right zack @zcarpenter92)
    https://www.tundras.com/threads/2018-toytec-customer-appreciation-day.22128/
  14. Apr 18, 2018 at 9:58 PM
    Jackson
    Jackson New Member
    Theron
    WY
    Awesome! Thanks. I look forward to seeing what it's about.
    Thegr8punkin[QUOTED] likes this.
  15. Apr 21, 2018 at 2:54 PM
    Jackson
    Jackson New Member
    Theron
    WY
    Connor. I did exactly what you said to do. AND IT WORKS NOW! Thank you thank you! I even bought a tb positioning sensor in case the cleaning didn't work, but I will be taking it back to NAPA. Again, thank you!
  16. Apr 23, 2018 at 6:18 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    No problem dude.
    Jackson[QUOTED] likes this.
