Why don't the wheels fit?
Discussion in 'Wheels & Tires' started by arctictundra8577, Mar 25, 2020.
  1. Mar 25, 2020 at 6:30 PM
    arctictundra8577
    arctictundra8577 [OP] New Member
    Eric
    Ontario, Canada
    2005 tundra sr5
    I tried to put my new set of wheels on my truck today, but the studs are too small for the wheels to fit. I've seen other people put these wheels on their trucks just wondering why they don't fit on mine. If you have any ideas let me know, thanks.
  2. Mar 25, 2020 at 7:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What do you mean the studs are too small? They arent long enough?
    What lug nuts are you using?
  3. Mar 25, 2020 at 7:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Steel wheels, may be an issue, as the lugs may be too wide to fit properly... Possibly the reason your studs are short as well??
  4. Mar 25, 2020 at 9:41 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Hmmm. Studs too short? Stud spacing not matching wheel? Studs too fat for wheel lug holes? We needs more info. LOL. Throw the wheel on the truck and post a pic. Pics always helpful. Pics or it didn't happen.
  5. Mar 25, 2020 at 11:21 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I know when I bought aftermarket wheels for my 2014 the lugs seems a bit short.
    The lugs were shorter in the front than in the back.
    E429CC0D-E4A8-40C6-800C-DFD0FD96FBC8_zps_354bd1e0725a7d40941515a31e2fcce5c9050fed.jpg
    1130C481-E842-4B39-8BE0-0B182D13EECA_zps_eb89216134f7ebd29d9b306557f7c41f388cf7ef.jpg
    After 7 re-balances, 4 of them road force, I could not get rid of the steering wheel shimmy.
    Aftermarket wheels, steering wheel shimmy, OEM TSS wheels, no shimmy.
    Even tried ET lugs and still had shimmy.
    D9151B90-57E2-46F2-8944-5AC340E7CF8C_zps_c54ba820d97023708e92b3ce8c621c4c92da1ab3.jpg
    Sent the wheel seller documents of the balances and they let me return them for a refund, shipping included.
    I got really lucky, still running the OEM TSS wheels...
  6. Mar 26, 2020 at 12:10 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    those are the same wheels i had on my tundra... they fit fine with OEM lug nuts. theyre tacoma TRD sport wheels
    revtune and landphil like this.
  7. Mar 26, 2020 at 1:26 AM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    check the hub and make sure it is clean from rust and debris, could be causing the wheels not to sit flush on the rotor
  8. Mar 26, 2020 at 4:26 AM
    Tundyfundy
    Southern California
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Could it be possible you have a wheel spacer installed?
  9. Mar 26, 2020 at 12:13 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    no everything on the truck is stock
    the nuts would only go through 4-5 turns
  10. Mar 26, 2020 at 2:36 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    I think the problem here is you don't have the right lug nuts for this wheel. The picture you posted shows and acorn style nut and the wheel shown requires a shank style lug nut, those have a shank that goes inside the wheel and the seat is on the face of the nut head. The wheels look like they fit fine you just need the proper lug nut.
  11. Mar 26, 2020 at 2:42 PM
    speedtre
    speedtre New Member
    Inland Northwest
    What he said....
    You need something like these for the OEM aluminum wheels...
    https://www.amazon.com/White-Knight...1--8-1-2643--4&vehicleName=2006+Toyota+Tundra
    Your's appear to look like this...
  12. Mar 26, 2020 at 3:40 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    41bigdawg and speedtre[QUOTED] like this.
  13. Mar 26, 2020 at 3:42 PM
    artsr2002
    'Yonder
    I concur. M'yes. m'yes.
  14. Mar 26, 2020 at 7:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Always a bummer when your nuts don't work.
    Tundyfundy, GODZILLA, bmf4069 and 3 others like this.
  15. Mar 27, 2020 at 10:41 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    5 threads, red locktight, lots of ugga duggas. Good to go.
    turboser91 and Darkness like this.
  16. Mar 27, 2020 at 1:43 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    You can probably swing by any Discount Tire and they have the right nuts in stock so you aren't waiting around for shipping.
  17. Mar 27, 2020 at 4:50 PM
    Professional Hand Model
    Hand Protectors
    Shapes and sizes and how they fit testing. Reminds me of the 1st Grade back in Appalachia. Pops was a good man working those coal mines.
  18. Mar 27, 2020 at 6:19 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Eaaassyyy on the ugga duggas.
    bmf4069[QUOTED] and FrenchToasty like this.
  19. Mar 27, 2020 at 7:50 PM
    Tundyfundy
    Southern California
    "Slow Clap":hattip:
  20. Mar 27, 2020 at 8:40 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Even worse if they fell off.
    bmf4069 and Tundyfundy like this.
  21. Mar 27, 2020 at 9:00 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I too once needed nuts. My nuts weren't good enough.
    bmf4069, Tundyfundy and TXTundra2722 like this.
  22. Mar 27, 2020 at 9:41 PM
    TXTundra2722
    2015 Black Tundra
    Now "she" has them huh.......or is it "he"?
    :monocle:
    :rofl::rofl:
