Why does cab style matter when replacing headlights?
Discussion in '1st Gen Tundras (2000-2006)' started by Twoshot, Feb 1, 2023.
  1. Feb 1, 2023 at 10:39 PM
    Twoshot
    Twoshot [OP] New Member
    04 Toyota Tundra Limited
    Can someone please tell me why does it matter the cab Style of my 04 Toyota when it comes to replacing the headlights I have a 04 Toyota Tundra Limited four-door and most aftermarket headlights do not fit four doors why they always say it's regular cab or extended cab the little doors and I want to know why
  2. Feb 2, 2023 at 12:28 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    The double cab is different in so many minor ways that it should be considered its own separate model. There’s a ton of things (headlights are one) that differ between the two.
    To specifically answer your question, the DC headlight housings are slightly larger in both height and width than their AC counterparts.
  3. Feb 2, 2023 at 1:44 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Mine are TYC brand, You can get them on rockauto.
  4. Feb 2, 2023 at 2:08 AM
    Crew Chief 66
    Crew Chief 66 New Member
    Vince
    Thomasville GA
    06 DC 2WD
    Are the TYC brand a good fit ?
  5. Feb 2, 2023 at 2:51 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    If you buy the right ones...
  6. Feb 2, 2023 at 9:58 AM
    shifty` Rappenin' is what's happenin'
    TYC and DEPO typically make solid stuff.
    But if you're worried about fitment, just spend the extra on OEMs. I waited for a sale at the Toyota Parts site and, if memory isn't failing, after all the discounts, no tax, free ship I think I paid $325 for both, fully-loaded with new bulbs, seals, etc.
  7. Feb 2, 2023 at 10:00 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    04 Double Cabs use different headlight assemblies than 05-06 Double Cabs and any of the AC/RC models. 04 Double Cabs share headlight assemblies with the 01-04 Sequoia.
    shifty` likes this.
