Which offset works for me??
Discussion in 'Lighting' started by Abdul98, Nov 16, 2020.
  1. Nov 16, 2020 at 9:41 PM
    Abdul98
    Abdul98 [OP] New Member
    Abdul
    2020 Toyota Tundra limited double cab
    Hello everyone, I put some new tires on my truck (destination X/T 275/65/18) sitting on the stock wheels. I'm looking into getting new wheels. Something that pokes out from under the fenders about a quarter inch, just to give it a slight stance. I'm not sure which offset to go with and where to find the proper wheels for my setup. Anyone have any recommendations?
  2. Nov 17, 2020 at 2:21 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Not sure why you posted this thread under the "LIGHTING" sub-forum. Probably better if you moved it to the "WHEELS AND TIRES" sub-forum.
  3. Nov 17, 2020 at 2:59 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    OP the factory wheel is +65 offset. Most consider the sweet spot for Tundras somewhere around +18 - +25 range. This will generally give you the best clearance for bigger tires ( although that doesn't seem to be a factor here) an it doesn't stick out real far but has a subtle poke. The more + you go the less poke out side the fender an the more towards 0 or negative offset you go will give you more poke. I have +20 shown below... With 295/70
