Which direction is the tie rod end suppose to go?
Discussion in 'General Tundra Discussion' started by Harold_Z, Sep 14, 2022.
  1. Sep 14, 2022 at 4:55 PM
    Harold_Z
    Harold_Z [OP] New Member
    San Antonio TX
    2012 Tundra Overland Build
    I had my tundra lifted with 6" RC long time ago, and the stock tie rod ends starting to go out so I have ordered a pair of coach builder one. I have seen people install the tie rod ends from the button where the castle nut is above the knuckle and mine was done in the opposite way where the castle nut is under the knuckle.
    Which way is the right way? Or this is more depends on vehicle set up and the lift?
    Coachbuilder1 likes this.
  2. Sep 14, 2022 at 5:39 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.7k Supercharged 2008
  3. Sep 14, 2022 at 5:50 PM
    Harold_Z
    San Antonio TX
  4. Sep 15, 2022 at 10:13 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    The RC lifts install above the steering knuckle just as your stock tie rods are now. You'll notice our logo will be upside down and can just pull the bolt out and rotate the black tube 180 degrees. Be sure to install the tapered collar (sliver piece) into the hole with small side first.
