Where can i tap in for puddle lights?
Discussion in 'Lighting' started by sc134, Jan 18, 2019.
  1. Jan 18, 2019 at 10:34 AM
    sc134
    sc134 [OP] O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    I just purchased mirrors and they come with puddle light which should turn on with either the dome light or the little light bulb where your feet are in the drivers side.
    Question is, where would be the best place to get power from for this particular set up?
    The dome control switch would probably be best but what color is the wire?
    I have 2017 CM SR5 Tundra.
    Thanks in advance! :)
  2. Jan 18, 2019 at 10:38 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Tap into the little light bulb housing that is for the parking brake. The puddle lights are suppose to come on when you lock, unlock or open the door. That's the perfect option for that. I tapped into that for my led strip lights for my steps.
    65SNAKE, rycherd and 56Pete like this.
  3. Jan 18, 2019 at 11:15 AM
    sc134
    sc134 [OP] O.P.S.
    It’s the little bulb right, it only has a power and ground wire? I haven’t really looked in the back side of it.
    Thanks for the help
  4. Jan 18, 2019 at 12:32 PM
    TundraTSS19
    San Antonio, TX
    Yes it's the only little tiny light that's there above the parking brake.
  5. Dec 12, 2021 at 5:41 AM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    Good thread...exactly what I've wanted to do. My concern was if the wire going to the courtesy light was heavy enough to provide enough current for the LED's.
  6. Dec 12, 2021 at 6:02 AM
    2mchfun
    Tap the bigger pink wire under the drivers door sill. Worked fine here.
    Taco-Spike likes this.
  7. Dec 12, 2021 at 7:44 AM
    The footwell light should not have constant power.
  8. Dec 12, 2021 at 9:11 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Power might already be at the mirror connector.
  9. Dec 19, 2021 at 4:02 PM
    It's not on the SR5.
  10. Dec 20, 2021 at 4:39 AM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    My truck looks exactly as yours...I used two strips on each side and tapped into the wires for the foot-well light.
    NewImprovedRon likes this.
  11. Jan 18, 2022 at 8:07 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    Which LED strips did you use? Looking into those options now. The RGB options would be nice for the purposes of red light while I'm camping. I want to wire these lights up as shown in Post #2. I'm worried those LED strips with color changing options won't play nice for my intended purposes.
    rdiddy5 likes this.
