When truck is idling and I turn the steering wheel.....
Discussion in 'General Tundra Discussion' started by jvt3, Dec 23, 2020.
  1. Dec 23, 2020 at 5:59 PM
    jvt3
    jvt3 [OP] New Member
    the RPM's change a bit....I mainly notice this when I first start it and sit there for a few minutes before driving away....
    When turning the wheel, the RPMs go up alot, then down......
    Is that normal?
    p.s. I forgot to look for it after driving around and then putting it in park....but it probably still happens then too....not sure...
  2. Dec 23, 2020 at 6:06 PM
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    Yep normal in any car
  3. Dec 23, 2020 at 6:31 PM
    bjohnson425
    bjohnson425 New Member
    Brandon
    Power steering pump engages which adds load to the serpentine belt system which makes it fluctuates. This happens on al
    Last all vehicles unless they have electronic power steering.
    Baja Mike likes this.
  4. Dec 23, 2020 at 6:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Belt-driven, hydraulically boosted power steering.
  5. Dec 23, 2020 at 6:46 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    There's a pressure sensor that boosts the RPM's. Older cars didn't usually have one. They can sometimes stall if the RPM's are just low enough when you crank the wheel all the way.
  6. Dec 23, 2020 at 7:09 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Unless it’s steer by wire that’s normal .
  7. Dec 23, 2020 at 7:15 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Normal. Same thing happens when you turn on your A/C. Putting a load on an idling engine.
  8. Dec 23, 2020 at 7:51 PM
    jvt3
    It's really fun when it happens while your driving 60mph around a dangerous curve.....turn the wheel...rpm's (and speed) shoot up to 90mph.....
    Nah...hasn't happened yet. Yeah, a few minutes after I first posted, I thought about it and said to myself: "power steering..needs power...!! got it!"
    But your posts gave me more details....good. I never noticed it with my old truck though......as someone said..older cars didn't.......
