When/If will Tundra Pro grille sensor garnish reduce in price?
Discussion in '2.5 Gen Tundras (2014-2021)' started by americanaaron, Jun 7, 2019.
  1. Jun 7, 2019 at 9:55 AM
    americanaaron
    americanaaron [OP] USA
    North Carolina
    2019 Tundra
    Anyone have any info if the Tundra Pro garnish ($280ish) will come down in price to the range of the Tacoma Pro garnish ($50 ish)?
    egibson606 likes this.
  2. Jun 11, 2019 at 7:12 PM
    msbaugh440
    msbaugh440 2019 limited, TRD package, cement
    Utah
    2019 Tundra limited, TRD off road, Cement
    Do you know if you have to re-calibrate the sensor if you sealed or does it just plug and play?
  3. Jun 12, 2019 at 11:33 AM
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    I've been wondering this as well. I really want a pro grille but cannot justify paying almost as much as the grille itself for a small square piece of plastic. Especially since the Toyota emblem garnish and Tacoma pro garnish are only around $50. Hoping the 2020 pro might fix this overpriced problem.
  4. Jun 13, 2019 at 4:15 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Technically any time you adjust or change the sensor position it needs to be recalibrated with the camera to align properly.
  5. Jun 13, 2019 at 12:19 PM
    coTony
    Tony
    Montrose, CO
    I have had my grill off and on I have no clue how many times and never required recalibration, there are tolerances there and no way it can be exact.
    Taking the senor off the grill and back on is another thing I have done I have no idea how many times and never needed recalibrated. Just like the grill there are tolerances and the radar at the mirror and the sensor have to have built in or things would never work.
  6. Jun 13, 2019 at 12:44 PM
    Zero One Actual
    I got my garnish from ares customs for $140 for my pro grille on my 2019. It is a new design he has made. His original version and V2 had some issues as already described in other threads here.
    I have had no issues with mine and have 2000 miles on it so far.
  7. Jul 27, 2019 at 2:44 PM
    ninjajay
    H-tine TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Volk TE37XT 18x9.5 +0, Nitto Terra Grappler G3
    Ares is at $100 or so,I think.
    OEM copy on ebay is around $139
    I think it took a year or so for the Tacoma ones to hit $40-50 so personally I'd wait
  8. Jul 29, 2019 at 4:48 AM
    coTony
    Tony
    Montrose, CO
    The dealer put a non Toyota radar shield on your truck??? With all the issues they have had and reprogramming the ECU for the radar correction and making the customer sign papers about their lifted vehicles I did not think for liability purposes Toyota would install a non factory item in front of a safety item
  9. Jul 29, 2019 at 1:36 PM
    americanaaron
    North Carolina
    2019 Tundra
    @phogallen Did you go with satin or gloss finish?
  10. Jul 29, 2019 at 5:11 PM
    Zero One Actual
    5000 miles now. Multiple four hour highway trips with all tech turned on. Zero issues. Multiple large south eastern rain and thunder storms, works fine in the rain also.
  11. Aug 4, 2020 at 11:57 AM
    Jerry Te37
    Jerry Te37 New Member
    Jerry
    Lapalma ca
    2014 2wd white tundra cm
    Jdm volk racing 20inch te37 Level rear end Morimoto headlight
    Did anybody try the Tacoma sensor cover to tundra ? I’m trying upgrade my 2014 grill to 2019 tundra pro, I need to cover the hole sensor. Probably modified it?
