Wheel/tire size comparison website
Discussion in 'Wheels & Tires' started by tuckertravis, May 16, 2018.
  1. May 16, 2018 at 6:55 PM
    tuckertravis
    tuckertravis [OP] New Member
    Tucker
    Abilene, TX
    2018 TRD Sport Crewmax
    None... Yet
    been running numbers on this website to get some ideas. Anyone else used this website or have input on how accurate the numbers are? Thanks in advance
  2. May 16, 2018 at 7:01 PM
    sr5shark
    sr5shark No matter where you go, there you are.
    Alan
    Walnut Creek, CA
    2016 SR5 CrewMax 4x4
    Bilstein 5100's |SCS SR8 w/ GY Duratrac | TRD rear sway bar
    I used this a lot when doing my research for tires. In general the info is accurate but it is also good to check the tire manufacturer site for specs. For example, if you enter the tire size 33x12.5x18 the site will show you this size. When you go to Toyo's website and look up the OpenCountry R/T the actual size is 32.8x12.5x18.
  3. May 16, 2018 at 7:05 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    Thanks
    Just trying to decide what setup to pull the trigger on. Want the look of 0 offset but not wanting all of the hassle of heat molding/trimming if the tires rub way too much
