Wheel Offset Question
Discussion in 'Wheels & Tires' started by GSRtrent, Apr 29, 2019.
  1. Apr 29, 2019 at 5:21 AM
    GSRtrent
    GSRtrent [OP] New Member
    2014 CM. Has a 2.5/1.25 leveling kit. What offset do I need to best fit 35 inch tires with minimal trimming?
  2. Apr 29, 2019 at 5:38 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  3. Apr 29, 2019 at 6:10 AM
    GSRtrent
    Thank you. What tire width would you recommend? I was thinking 11.5" wide.
  4. Apr 29, 2019 at 7:32 AM
    ninjajay
    Spoolston, TX
    That sounds like 295/70/18 which is extremely common on this forum. You should be in good shape with doing the fender liner mod
  5. Apr 29, 2019 at 7:39 AM
    GSRtrent
    Thank you. I'm just hoping I won't have to do the body mount chop modification.
  6. Apr 29, 2019 at 8:01 AM
    ninjajay
    Spoolston, TX
    Every truck is different but in theory no
  7. Apr 29, 2019 at 8:04 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
  8. Apr 29, 2019 at 8:05 AM
    GSRtrent
  9. Apr 29, 2019 at 8:08 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    No problem. As you can see, where you're at currently, I can't see you getting into 35s without the BMC.
  10. Apr 29, 2019 at 8:11 AM
    GSRtrent
    True. I might go with 33.5 inch. I'll have to do some more research. Right now I'm running 33's with no issue. No trimming or nothing.
  11. Apr 29, 2019 at 8:26 AM
    ninjajay
    Spoolston, TX
  12. Apr 29, 2019 at 8:32 AM
    GSRtrent
  13. Apr 29, 2019 at 8:37 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Also check 285/75/18 34.8x11.2
    It will be close. Best offset is +18-+25
  14. Apr 29, 2019 at 8:39 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
  15. Apr 29, 2019 at 8:41 AM
    GSRtrent
    What offset are your wheels?
  16. Apr 29, 2019 at 8:48 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    I'm higher now. +2 more inches (total of 4"). Plus I have custom fender wells. My wheels now are Method Vex 311s. 0 offset.
    My old Pro wheels were stock, so 18x8 +60mm offset, 5 x 150mm. And I ran Nitto Terra Grapplers in 295/70/18. Required plastic trimming but no BMC. But to me, they were skinnies, and looked like skinnies.
  17. Apr 29, 2019 at 9:04 AM
    GSRtrent
    Thank you for the info.
    jewsNbrews likes this.
