wheel fitment question
Discussion in 'Wheels & Tires' started by Henry2019, May 15, 2022.
  1. May 15, 2022 at 9:09 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60/R20 Falken Wildpeak A/T3W
    would a 50+ offset with 35X12.50/35X11.50 tires fit a 2014-2021 Tundra with a 3 inch front and 1 inch rear lift? If so, would any modifications be needed?
  2. May 16, 2022 at 6:41 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
  3. May 16, 2022 at 7:00 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What tires? Not all 35s are true 35 inch diameter.
    I would start here: https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
    "3″ Lift Kit
    With a 3″ lift kit, the options continue to get better. However, the wider the tire, the greater the likelihood of trimming.
    Max tire sizes are:
    • 18″ rims: 285/75 R18 – 4/10ths wider and 2.8″ taller than factory.
    • 18″ rims: 305/70 R18 – 1.2 inches wider and 2.8″ taller than factory. There are Tundra owners running this size, but trimming is required. Replacing the stock wheels with after-market 18′s that have less backspacing is recommended."
    • 20″ rims: 285/65 R20 – 4/10ths wider, 1.6″ taller than factory.
    • 20″ rims: 305/60 R20 – 1.2 inches wider and 2.4″ taller than factory. There are Tundra owners running this size, but trimming is required (it’s a tight fit).
    35s with no BMC/CMC here:
    https://www.tundras.com/threads/how-to-fit-35s-without-a-can-mount-chop.93341/
    https://www.tundras.com/threads/smallest-lift-so-i-can-get-35-tires.41032/
    From reading many of the fitment threads +18 to +25 seems to be the sweet spot for 35s with no BMC/CMC. Typically the front air defuser (what people are calling mudflaps) needs to be removed to allow for the unobstructed wheel scrub. UCAs come into play to push the wheel forward away from the bodymount area and seems to be a recommended option for 3 inch lifts.
  4. May 18, 2022 at 11:10 AM
    Saltyhero13
