Wheel Bolts from 20" to 18"
Discussion in 'Wheels & Tires' started by wwolvverine, Feb 24, 2019.
  1. Feb 24, 2019 at 3:17 PM
    wwolvverine
    wwolvverine [OP] New Member
    2018 Tundra 1794
    Just to make sure the Lug Nuts used in a 20" OEM rim can be used for OEM 18" rim right?? I mean the threads don't change from the truck and both are original rims.
    Thanks
  2. Feb 24, 2019 at 3:30 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No difference.
    wwolvverine[OP] likes this.
  3. Feb 24, 2019 at 3:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    As long as the 18 are alloy. Steel uses different nut
  4. Feb 24, 2019 at 3:34 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    if same style wheel your ok, For example, changing from steel to alloy you may need new lugs
