Wheel and tire size
Discussion in 'Wheels & Tires' started by Tundraguy779, Jan 16, 2017.
  1. Jan 16, 2017 at 3:44 PM
    Tundraguy779
    Tundraguy779 [OP] New Member
    2017 White Tundra TRD
    Front end leveling kit
    Just purchased a 2017 Toyota Tundra Crewmax TRD and put a 3 inch front end leveling kit on it. Now looking to see what size wheel and tire size I can go? What do you all think?
  2. Jan 16, 2017 at 3:49 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
  3. Jan 16, 2017 at 4:01 PM
    Tundraguy779
    What size wheel and tire size did you go?
  4. Jan 16, 2017 at 4:04 PM
    joem1cha3l
    Albany, NY
    Im running 18" +12mm offset right now with 275/70/18's
    On wednesday I have 295/70/18s being put on
    Law323 likes this.
  5. Jan 16, 2017 at 4:05 PM
    joem1cha3l
    Albany, NY
    I went with +12 offset because I had fender flares. If I could do it over again, since i took the flares off, I would have went +18.
    zcarpenter92 likes this.
  6. Jan 16, 2017 at 4:07 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Biggest u can go without new wheels or spacers are 295 70 18 or a 305 65 18. Anything bigger u need a lower offset or spacers +18 to 30 will fit great.
    Law323 likes this.
  7. Jan 16, 2017 at 4:08 PM
    xtyfighterx
    Ty
    North Idaho
    That's with minor trimming of the inner fender and removal of the rear mud flaps
  8. Jan 16, 2017 at 4:09 PM
    Tundraguy779
    Nice, I was thinking the same 295/70/18 w/18". I don't have fender flairs yet. Worried the extra 2" will need them.
  9. Jan 16, 2017 at 4:10 PM
    xtyfighterx
    Ty
    North Idaho
    I had 295 70 18 with +18 and added flares it took away the aggressiveness of it. I'll see if I can find a pic. I'm now running 0 offset with my 295s
  10. Jan 16, 2017 at 4:15 PM
    joem1cha3l
    Albany, NY
    This is exactly why I removed my flares. Made the tires and wheels look small. Took them off and the truck looked awesome again.
  11. Jan 16, 2017 at 4:19 PM
    xtyfighterx
    Ty
    North Idaho
  12. Jan 16, 2017 at 4:20 PM
    xtyfighterx
    Ty
    North Idaho
  13. Jan 16, 2017 at 4:22 PM
    xtyfighterx
    Ty
    North Idaho
    Now that I'm running 0 offset I think I'll try and find some color matched ones. Think it will look a lot better it just took the whole stance away with +18
  14. Jan 16, 2017 at 4:25 PM
    joem1cha3l
    Albany, NY
    Ty. Just consider leaving it the way it is without the flares.....truck is fucking sick
    xtyfighterx and KCTundra like this.
  15. Jan 16, 2017 at 4:26 PM
    xtyfighterx
    Ty
    North Idaho
    Haha thanks man. Can never stop tho it's a problem. Bed bars roof top tent and other goodies are on order currently.
  16. Jan 16, 2017 at 4:27 PM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Truck definitely looks good.
    xtyfighterx likes this.
  17. Jan 16, 2017 at 4:27 PM
    xtyfighterx
    Ty
    North Idaho
    The 0 offset really slings the mud and rocks and black paint shows it all
  18. Jan 16, 2017 at 4:27 PM
    Tundraguy779
    Your right! It looks mean without the flares.
  19. Jan 16, 2017 at 4:29 PM
    Zharris
    Zharris Merica!
    The reason I went with the +30 offset with the flares. It definitely doesn't have the most aggressive look, but pretty much everything stays under my flares. I'm not a huge fan of dents and dings in the side of my truck.
  20. Jan 16, 2017 at 4:35 PM
    xtyfighterx
    Ty
    North Idaho
    Might go with oe flares over the pocket they don't stick out as much
  21. Jan 16, 2017 at 4:50 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    I'm looking at 18 x 9 wheels, and the shop is suggesting BFG KO2's in either 285/65 or 305/65.....I'm not doing the flares.
    The above will either be with Billsteins front and back or the Toytec Boss kit to level things out.
  22. Jan 16, 2017 at 5:20 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Congrats on the 2017 CM. I am running a 285/75R-18 on OEM wheels powder coated . Tire is equal to 35x11.50. I just prefer the tucked look with the OEM wheel. Let us know which route you choose.
  23. Jan 16, 2017 at 6:16 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I love the way my +18s sit on the truck on a 295 tire.
    Zharris, Tundraguy779[OP] and R-C like this.
  24. Jan 16, 2017 at 9:52 PM
    Morgan51
    Morgan51 New Member
    2016 Inferno CM Tundra TRD
    I'll probably end up with these @SCSPerformance wheels once they come out, and I have the money to spend... 18x9 +25 offset and 295/70r18s sound like a good setup... won't stick out too much to where you're worried about going down a gravel road, but will give it a nice stance! :thumbsup:
    SiLV3R, J4RR3N4 and joonbug like this.
  25. Jan 17, 2017 at 7:19 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Highest tire size you can feasibly go with minor trimming is 295/70. Could bump up to 35's with a CMC.
    Wheel size doesn't matter. Most go 18's or 20's. It's all up to your preference.
    Offset- sweet spot is usually between 18-35 on tundras. Any more or less, you'd have to think about UCA rub (more offset) and more trimming (less offset)
    zcarpenter92 and joonbug like this.
  26. Jan 17, 2017 at 10:42 AM
    SiLV3R
    SiLV3R New Member
    17 Silver Tundra
    Undercover Flex, Bedrug Liner, ESP Aluminum Storage Unit, Method NVs.
    Do you know when they are projected to come out? Thanks!
  27. Jan 17, 2017 at 3:38 PM
    Morgan51
    Morgan51 New Member
    According to this thread, 1.5 weeks out from release :thumbsup:
  28. Jan 17, 2017 at 3:59 PM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    15' trd pro
    pro comp at sport
    35 12.5 18
    2 shims
    spacers
    cab chop
    bumper shim
    wonderful ride
    CM-LENNY likes this.
  29. Jan 17, 2017 at 4:02 PM
    Morgan51
    Morgan51 New Member
    :ohsnap: Truck goals.. How do you like the pro comp tires?
  30. Jan 17, 2017 at 4:07 PM
    CM-LENNY
    San Diego, CA
    Nice looking truck Matt............
