Whats a good lift to clear 35s
Discussion in 'Suspension' started by EdwinGuz301, Mar 22, 2020.
  1. Mar 22, 2020 at 5:07 PM
    EdwinGuz301
    EdwinGuz301 [OP] New Member
    Edwin
    2013 Toyota Tundra SR5 Crewmax
    Ive seen many videos that you can clear 35s with only a 3 inch lift. I don’t know if thats true i would imagine you need to do a body chop as they call it but i was interested in the bds 3in coil over kit. Need some help!!
  2. Mar 22, 2020 at 5:32 PM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    I have pro comp w 6in w 35. Perfect fit
    Prostar 190 and EdwinGuz301[OP] like this.
  3. Mar 22, 2020 at 5:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    No lift needed. Grinding wheels and a BFH will do.
  4. Mar 22, 2020 at 5:41 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Go with a 6 inch or wish you did ..
    2010bigdog and Prostar 190 like this.
  5. Mar 22, 2020 at 6:03 PM
    EdwinGuz301
    Edwin
    What kind of lift do you have on your truck by the way both look great
  6. Mar 22, 2020 at 6:04 PM
    EdwinGuz301
    Edwin
    Any issue with ride quality and what tires are you running
  7. Mar 22, 2020 at 6:54 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The red one is mine and the other is a friends, They both have Procomp 6 inch lifts. There are less expensive 6 inch lifts made by Rough Country that are just as good. Around a grand. I think.
  8. Mar 22, 2020 at 7:58 PM
    rustytoys
    rustytoys New Member
    The width is a bigger factor than height really; what size tires and wheels were you thinking about? Do you like the "stuffed" tire look? - If not then consider at least a 4.5" lift.
  9. Mar 22, 2020 at 8:06 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    All you need is this :sawzall:and it will still have the factory ride.
    15whtrd and GNTundra like this.
  10. Mar 22, 2020 at 8:12 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    6” Hands down...
    2010bigdog, Prostar 190 and jeremyd like this.
  11. Mar 22, 2020 at 8:39 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I have no issues with 3/1 leveling kit and I personally like the look over a 6 inch lift. It's all personal preference.
    equin, 15whtrd and Backslider like this.
  12. Mar 23, 2020 at 2:54 AM
    6" and 35's
    2010bigdog and jeremyd like this.
  13. Mar 23, 2020 at 3:01 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Info in Signature below.
    O.S.T.
    MTRock likes this.
  14. Mar 27, 2020 at 4:32 PM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    equin and Elduder like this.
  15. Mar 27, 2020 at 4:59 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD /2026 TUNDRA LIMITED
    Id love to but really don't want the crossmember cut
  16. Mar 27, 2020 at 5:28 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yea, I definitely understand that, it’s a big hurdle for alot of people.
    2010bigdog[QUOTED] likes this.
  17. Mar 27, 2020 at 5:56 PM
    2010bigdog
    Chuck
    Chicago
    So I’m going with the PROCOMP 4” but trying to figure out what offset I need and what wheel I want to go with
  18. Mar 28, 2020 at 6:45 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Negative offset dictates a lot of what you're asking about. Lift is good for height of tire clearance but tires move in that wheel well. If you decide to go with a huge negative offset you'll need more height & possible aftermarket bumper to clear unless rubbing doesn't bother you
  19. Mar 28, 2020 at 6:47 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wouldn't go higher than a leveling kit to 3" then.
  20. Mar 28, 2020 at 7:48 AM
    2010bigdog
    Chuck
    Chicago
    procomp makes a 4" with no cutting. Thats the one im pretty sure im getting
  21. Mar 28, 2020 at 8:26 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Here is mine with a 18x9 wheel with a -11 offset.
    I used a heat gun on the plastic in front of the tire to push it in a little to eliminate a tiny bit of rubbing. Apparently a smaller lift can be done with 35”s from what other people have posted but It may not give you the “look” you want..
    4985F170-F526-4E38-A9AE-C7FFCA8CD798.jpg E6140D57-C051-4CC4-9463-E5116B268C5B.jpg
    toyofan87 likes this.
  22. Mar 28, 2020 at 8:31 AM
    6" older RC lift, rear cross member is not cut, no rub, on 35's with +20 wheel, tires line up with flares, ride quality is stiff, but what I do with my Tundra I enjoy it
    15whtrd and jeremyd like this.
  23. Mar 28, 2020 at 8:33 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    This is not true unless you have a picture ! Lol
  24. Mar 28, 2020 at 8:34 AM
    What?
    jeremyd[QUOTED] likes this.
  25. Mar 28, 2020 at 8:34 AM
    2010bigdog
    Chuck
    Chicago
    can you send a pic of your truck from the side ?
  26. Mar 28, 2020 at 8:35 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    picture bro ! picture
  27. Mar 28, 2020 at 8:35 AM
    2010bigdog
    Chuck
    Chicago
    everything im looking at over 3" needs to be cut except the 4" procomp from what I see
  28. Mar 28, 2020 at 8:35 AM
    Of what?
  29. Mar 28, 2020 at 8:36 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    your beautiful self ! lol
  30. Mar 28, 2020 at 8:37 AM
    When I bought my Tundra used, I checked time n time, getting to know it, I called RC, spoke with techs sent email pics, they told me it's an older version lift, so my RCM is not cut, so technically I could remove this kit
    jeremyd likes this.
