What will happen if i go down to 18" wheels?
Discussion in 'Wheels & Tires' started by wwolvverine, Jan 23, 2019.
  1. Jan 23, 2019 at 11:51 AM
    wwolvverine
    wwolvverine [OP] New Member
    2018 Tundra 1794
    I am thinking about getting some 18" Michelin LTX's or something close to that. To smooth out ride a bit. I have all season sport Dunlaps 20"right now and they are brutal in the snow.
    1794 Tundra 2018
    Mountun Goat likes this.
  2. Jan 23, 2019 at 11:55 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    I'll let you know Friday if it makes any difference. I'm going from 18" to 20".
    wwolvverine[OP] likes this.
  3. Jan 23, 2019 at 12:08 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    From what I hear, ride quality will improve, tires will be cheaper, but the amount of panty dropping won’t change...it’s still a tundra! LOL
  4. Jan 23, 2019 at 12:09 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    More sidewall means more room to flex. So 18 will be slightly smoother ride.
  5. Jan 23, 2019 at 12:18 PM
    Philogynist
    Philogynist New Member
    NY
    If you're going to run the 18" wheel, you might consider going with a 275/70-18. Bear in mind that by doing that you will exceed the "stay within 3%" rule. There are a few members here that are running 275/70-18 tires.
  6. Jan 23, 2019 at 12:51 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Your balls will grow larger going to an 18”.
  7. Jan 23, 2019 at 12:53 PM
    Notachickmagnet
    Notachickmagnet New Member
    Mountun Goat[QUOTED] likes this.
  8. Jan 23, 2019 at 12:57 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    I run the 275/65 18. No complaints
  9. Jan 23, 2019 at 1:13 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    As far as a direct change it may throw off your speedometer a little.
    As far as everything else this is what I noticed going from an '11 Tundra with 20's to '16 with 18's.
    20's look better
    20's are slightly more responsive in turn in
    18's ride better
    18's have cheaper tires
    18's balance much easier.
    I've had 20's on my old F150 and Tundra. When I got my new truck I was hell bent on going back to 18's. Haven't looked back.
    Joe Dirt likes this.
  10. Jan 23, 2019 at 1:17 PM
    wwolvverine
    2018 Tundra 1794
    Gonna need new rims too, I forgot!!
  11. Jan 23, 2019 at 1:22 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    why move down to 18's when you can run 17's? As @Law323 stated above, 18's won't change the amount of pantie drops, but 17's will pay dividends. ;)Tundra wheels.jpg
  12. Jan 23, 2019 at 1:38 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    What size tires are you running?
    Do you have a lift?
  13. Jan 23, 2019 at 2:47 PM
    wwolvverine
    2018 Tundra 1794
    Looks good. But what about the rule of 3" for Trucks. Any change in your transmission?
  14. Jan 23, 2019 at 3:00 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Rule of 3”?
  15. Jan 23, 2019 at 3:01 PM
    Jengel451
    The Bitterroot, MT
    Running 315/70-17. probably could get away with 2" lift with UCA and be ok.
    You don't need to run a 35" though, you can go smaller.
  16. Jan 23, 2019 at 3:03 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    It will definitely look better.
  17. Jan 23, 2019 at 4:28 PM
    wwolvverine
    2018 Tundra 1794
    Changing Tire sizes like from 20 to 17. For cars it is 2". Messes up steering abilities and transmission.
  18. Jan 23, 2019 at 4:34 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    I went from stock 20s (same as 1794) on my 2018 trd sport to the TRD off road 18s with Michilen LTX At2 tires. The ride did indeed improve. IMG_20180307_104058_890.jpg
  19. Jan 23, 2019 at 4:38 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I’m a big fan of 18s! In my opinion they look great in terms of wheel to tire ratio. 17s are my absolute favorite but I may Get aftermarket brakes so I wanted the extra room in there.
  20. Jan 23, 2019 at 5:05 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Never heard of it, nor have I heard of problems going from 20’s to 17’s.
    Don’t see how that could mess up steering or transmission.
    Only thing I can see messing (or accelerating) wear is going up tire sizes in regards to outer diameter not wheel (rim) size
    Besides that, I’ve seen cars with 15’s go up to 20’s without any problems.
  21. Jan 23, 2019 at 5:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    He isnt changing tire sizes, just wheel size.
    Law323, Jengel451 and joonbug like this.
  22. Jan 23, 2019 at 5:58 PM
    Phishindude
    Phishindude New Member
    18s all day!
  23. Jan 24, 2019 at 10:21 AM
    jlattanzi91
    jlattanzi91 New Member
    2010 Toyota Tundra Sr5
    Pro Comp 6" Coilover Stage 2 Suspension lift Pro Comp Upper Control Arms Corsa Sport Cat-Back Exhaust BFG Ko2 35x12.5r18 Black Rhino Sprocket Wheels 18x9.5+6 EBC Rotors&Pads(Front) aFe Momentum Gt Intake aFe Scorcher programmer Remote Auto Start
    Less weight
    Better braking
    Thicker sidewall for better ride quality
  24. Jan 31, 2019 at 5:13 PM
    wwolvverine
    2018 Tundra 1794
    Boudin where did you get your Toyota rims? did they come with original purchase. Nice 18" style rims.
  25. Jan 31, 2019 at 6:35 PM
    Jerry70
    Jerry70 New Member
    Lakes region NH
    2019 Limited CM OR CAValry blue
    TRD exhaust, TRD rear sway bar
    Not a Tundra, but...I swapped sizes on both my 2nd and 3rd gen. Tacomas. I went from factory 17" sport wheels to the TRD Faux beadlock 16" wheels. I noticed nothing as far as handling or performance. I swapped back and forth between winter/summer.
  26. Feb 1, 2019 at 1:14 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    Bought them used on Craigslist, they were off a TRD off road model.
  27. Feb 4, 2019 at 9:16 PM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    I just took the 20's off my new Tundra, put 18's on it rides so much smoother. The 20's felt like I was on a forklift with solid tires. I think with 33's on the 18" rims it looks great!
  28. Feb 4, 2019 at 9:23 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I'm going from 20" BBS wheels to the 18" TRD Offroad wheels. Can't wait.
  29. Feb 5, 2019 at 6:27 PM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I am also looking to go to the 18's on my 2019 TRD Sport. I would like to get larger than stock tires too. Are you guys replacing the spare wheel and tire? I guess this is mostly a question for those that go to bigger tires, but I was told by a tire shop that your spare needs to match size or you could f-up your diff if/when you use it. Any thoughts?
