What type of flare do we have on stock brake lines?
Discussion in '1st Gen Tundras (2000-2006)' started by Jedgar, Jan 9, 2026.
  1. Jan 9, 2026 at 2:36 PM
    Jedgar
    Jedgar [OP] New Member
    2006 SR5 Double Cab 4WD, V8, forest green w/ topper
    None (no lift, don't want one), Bilstein 4600 shocks soon. Bigger Michelin tires soon.
    A brake line blew out yesterday, so needs to be replaced. Stock steel line under the hood, a long one (between what i think is the abs unit and a fitting down on the frame rail beneath the master cylinder area), majority of the line looks good except for the one corrosion spot that blew out.
    I have copper-nickle brake line material and bending and flaring tools (for double flares). Hoping I can make a new one myself.
    Then I get to pressure bleed the front brakes all over again. Just when I thought I had achieved good/decent brakes on the truck, after doing the front big brake upgrade last year. Oh well, atleast it happened within a few miles of home and not on a towing road trip.
  2. Jan 9, 2026 at 3:38 PM
    Aerindel
    Aerindel New Member
    Montana
    2000 Tundra AC, SR5, 4.7 V8 4WD, 340k'ish miles, 2008 Sequoia, 220k Miles
    Standard inverted flare, 3/16th" line with metric fittings. M10, I think.
    I think the only ones who use the bubble flare fittings are older European cars
    G_unit3000 likes this.
  3. Jan 9, 2026 at 5:27 PM
    Jedgar
    Standard SAE “double flare” ?
  4. Jan 9, 2026 at 5:52 PM
    koditten
    Kirk
    Midland of the Mitten
    Hi06silver, tvpierce and G_unit3000 like this.
  5. Jan 9, 2026 at 6:56 PM
    Jedgar
    Yeah, i’ve got the tools for double flare, just never had to replace a line on my 2006 DC. Replaced all the lines on a Ford this past summer and only missed putting the flare nut on one time. Hopefully the bleeding goes smooth as after the line blew l had to nurse it home and pumped all of the fluid out of the front circuit.
    G_unit3000 and koditten like this.
  6. Jan 11, 2026 at 2:35 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Would it make sense to use the fittings from the original? (assuming they are in decent shape)
    koditten[QUOTED] likes this.
  7. Jan 11, 2026 at 5:15 AM
    koditten
    Kirk
    Sure does. If they look good, they are fine to reuse.
    tvpierce[QUOTED] likes this.
