What size tires can I fit on my 2014 with a 4inch lift?
Discussion in '2.5 Gen Tundras (2014-2021)' started by matadoe, Feb 8, 2017.
  1. Feb 8, 2017 at 6:31 PM
    matadoe
    matadoe [OP] New Member
    Hello everyone! I'm new to this club and have a question. What size tires can I fit on my 2014 tundra TSS 4WD with a 4 inch suspension lift? I don't want any rub if I can avoid it. Also, should I stick with my 20inch wheels or go with another size? What size should I go with and any recommendations for wheels? I like the TRD pros...Thanks in advance!
  2. Feb 8, 2017 at 6:33 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    How much do you want to trim and cut?
  3. Feb 8, 2017 at 6:34 PM
    xtyfighterx
    Ty
    North Idaho
    I've seen 37s under a 4in but ur gonna have to trim a little
    matadoe[OP] likes this.
  4. Feb 8, 2017 at 6:44 PM
    matadoe
    Not sure to be honest. How much would I need to trim for 35s?
  5. Feb 8, 2017 at 6:45 PM
    matadoe
    Dang that looks nice! those are 37s?
  6. Feb 9, 2017 at 11:54 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    You could fit 35's with no trimming under a 4" lift. BTW, welcome from Las Vegas!!
  7. Feb 9, 2017 at 12:01 PM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    35 12.5 17's with no trimming under a 3" lift...
    PermaFrostTRD and matadoe[OP] like this.
  8. Feb 11, 2017 at 6:19 AM
    matadoe
    Thanks, gents! Nice looking rides. 35s with a 3 or 4 inch lift is what I'm shootin for. I want the TRD pro wheels 17s. Would I need the 17x7 or 17x8s?
  9. Feb 11, 2017 at 6:30 AM
    matadoe
    I like yours 650h1. That's exactly the look I'm going for. Sits nicely and the tires don't look too wide and spaced out. That looks perfect! Too bad we don't get snow like that down here in Houston, Texas!
