What Progamer??
Discussion in 'Performance and Tuning' started by Ronmat4X2, Jun 19, 2018.
  1. Jun 19, 2018 at 12:39 PM
    Ronmat4X2
    Ronmat4X2 [OP] New Member
    2007 4X2 TRD
    What would be a good progamer for 5.7
  2. Jun 19, 2018 at 12:42 PM
    Seen lots of members praise the Bullydog and Daptune
    15whtrd likes this.
  3. Jun 19, 2018 at 12:55 PM
    Ronmat4X2
    2007 4X2 TRD
    I got a buddy at work that said he hasn't had much luck with a programmer. I think he had the Bulldog. Querious how much improvement I could see in mileage and or power.
  4. Jun 19, 2018 at 1:20 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    For a noticeable increase in power, zero. That said, Bullydogs are popular for all the info and configurability they provide.
  5. Jun 19, 2018 at 1:54 PM
    BayRunner
    2017 Tundra Platinum
    Maybe a bit of an understatement. Yes, from a technical standpoint you may not notice the increase in "power' (raw HP). However, it does reprogram the ECU for premium fuel tuning and shift points where you definitely feel a noticeable difference in performance and responsiveness. Just my humbled opinion.
    15whtrd likes this.
  6. Jun 20, 2018 at 2:41 AM
    Ronmat4X2
    2007 4X2 TRD
    Would there be a noticable increase in fuel mileage?
  7. Jun 20, 2018 at 7:00 AM
    BayRunner
    Depends on your driving habits. Under normal driving, I picked up about 1 to 1.5 mpg. I also installed a S&B CAI at the same time, and do not know if this contributed in any way to the increased mpg.
  8. Jun 20, 2018 at 7:15 AM
    Ronmat4X2
    2007 4X2 TRD
    I have a S&B Cold air box, and I plan to remove the last 2 cats from exhaust, hopefully all will help, anyone else removed there last 2 cats and got an improvement?
  9. Jun 20, 2018 at 8:08 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It’s true. Measuring power output on a dyno or at the track can only be done above 4000 rpm. You can definitely feel a difference below that rpm with the Bullydog installed.
    Best way to put it, you can tune the truck to feel the way you want it to feel.
  10. Jun 20, 2018 at 9:25 AM
    Ronmat4X2
    2007 4X2 TRD
    Is there a setting on the Bulldog for better gas mileage, or can you tune it for better mileage?
  11. Jun 20, 2018 at 9:32 AM
    BayRunner
    There is an "eco" mode, but truthfully all it does is soften you pedal to prevent jack rabbit starts.. I've not tried it, nor do I care to. There is only so much you will get and face the fact that the Tundra is not made for fuel economy.
  12. Jun 20, 2018 at 9:34 AM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Nope...
