What order should I do these mods in?
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundrathr0w, Jun 17, 2018.
  1. Jun 17, 2018 at 9:47 PM
    tundrathr0w
    tundrathr0w [OP] New Member
    2018 Silver Sky Metallic Tundra CrewMax 4x4 5.7L
    Here are some exterior mods I want to do, but I'm not sure if there's a specific order to doing them, especially around the spraying of the underside:
    * Linex bed
    * Linex underside of truck
    * Install running boards (any recommendations?)
    * Install tonneau cover (any recommendations?)
    For example, do I need to Linex spray the underside of the bed AFTER installing the mounts for the running boards, so they get sprayed as well?
  2. Jun 17, 2018 at 10:00 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Where do you live? Do you need to line-x the underside of the truck? I’d put running boards on and line-x the bed... check out Go rhino...
  3. Jun 17, 2018 at 10:03 PM
    gosolo
    Ray
    NW Oregon
    What color is your truck? Let’s see some pictures
  4. Jun 17, 2018 at 10:11 PM
    ZPMAN
    Minnesota
    Supercharger should be first.
    ninjajay and 4x4_Angel like this.
  5. Jun 17, 2018 at 10:55 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Do the underside line-x before you install the running boards. Do the bed line-x before you add the cover.
  6. Jun 18, 2018 at 7:03 AM
    tundrathr0w
    Thanks. What's the rationale for this?
  7. Jun 18, 2018 at 8:07 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    Running boards
    Line-X
    then Cover
    Do all your line-X in one shot if you can. Less down time with your truck.
    Line-X after running boards just in case. When my bed was done they line-x'd over some of the bolt holes of my anchors, which becomes a PITA when your need to try to peel it all out so you can remove them. If they did this to your bolt hole for the running board you'd be F'd. A good shop probably wouldn't have this problem so it depends on who your dealing with.
  8. Jun 18, 2018 at 8:41 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    To avoid the extra labor in removing and reinstalling these accessories in order to line-x the underlying surfaces. Sort of like painting a wall before you hang a picture.
  9. Jun 18, 2018 at 8:46 AM
    tundrathr0w
    Looks like you and mtTundra disagree on whether to Linex the underside or install running boards first... will it be hard to remove the bolts once the underside has been sprayed?
  10. Jun 18, 2018 at 8:48 AM
    tundrathr0w
    If I Linex after the running boards, will the Linex shop just spray on top of the running board bolts??
  11. Jun 18, 2018 at 9:45 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    most likely. A good shop will cover the bolt or thread tho.
    Also as others have said probably want to have the running boards sprayed anyway if your doing the underside.
