What motor oil are you running?
Discussion in 'General Tundra Discussion' started by onetohunt, Sep 8, 2017.
  1. Sep 8, 2017 at 12:11 PM
    onetohunt
    onetohunt [OP] New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    Was curious as to what oil you are running?
  2. Sep 8, 2017 at 12:39 PM
    TheBeast The Beach
    us gen 2s not cool enough to run the same oil :(
  3. Sep 8, 2017 at 12:48 PM
    onetohunt
    Marvin
    No not at all. I was under the impression that it was basically synthetic oils only in the Gen 3's? Maybe wrong. It's just that I have a Gen 3 truck and was curious.
  4. Sep 8, 2017 at 2:08 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Gen 2's have the same motor as the Gen 3's. Mobile 1 Ow-20.
  5. Sep 8, 2017 at 4:39 PM
    gosolo
    Ray
    NW Oregon
    I began running mobile 1 synthetic in in my 2001 taco.
    Synthetic is better than dyno oil 2 to 1.
    It's good to start with synthetic on a brand new truck and keep it that way.
    Even if you have been running dyno oil for 200,000m it's still better for your engine to begin using synthetic oil.
    It's more expensive than dyno oil but worth it unless you're not planning to keep your vehicle very long.
    WildBoar likes this.
  6. Sep 8, 2017 at 4:49 PM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    I'm using whatever the dealer puts in it but once the freebie oil changes are over, it will be Mobil 1 extended performance with a TRD oil filter or the Mobil 1 oil filter. Also, I am gonna start pulling oil samples at the oil change interval to get an idea how long I should run my oil.
  7. Sep 8, 2017 at 4:51 PM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
    Mobil1 Full Synthetic 0w-20 Toyota oem oil filter
    Ajkkane, BTBAKER and gosolo like this.
  8. Sep 8, 2017 at 5:21 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Mobile1 5w-20 High mileage
  9. Sep 8, 2017 at 5:23 PM
    Petroleum 1
    Petroleum 1 New Member
    Colorado / Arizona
    I'm doing exactly what mr wrench is doing :)
    Mountun Goat and MrWrench like this.
  10. Sep 8, 2017 at 6:22 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I ran Castrol synthetic in my Taco and that is what I plan to run in the Tundra. That is unless I find Mobil 1 on sale.
  11. Sep 9, 2017 at 10:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    I drained the engine oil to save weight and improve gas mileage.
    Uhhhh...., Mwray8909, runCMD and 8 others like this.
  12. Sep 9, 2017 at 10:59 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I used mobil 1 or Pennzoil full synthetic 0-20 (which ever was on sale) and OEM Toyota filter on my only oil change to date
    Ajkkane likes this.
  13. Sep 9, 2017 at 11:20 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Mobil One F/S
    0w20
  14. Sep 9, 2017 at 11:50 AM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Royal purple and Toyota OEM Filter in my 2008 tacoma for the past 4 years. Previous to that was Mobil one synthetic.
    I suppose once the freebies are up on the tundra, it will be royal purple and OEM filter as well...
  15. Sep 9, 2017 at 6:07 PM
    Lilly
    Lilly New Member
    Troy
    North Carolina
    2015 White Tundra 1794 Edition
    4-6" RCD Lift System, 20" Moto Metal Rims. PIAA LED Light bar, Tonneau Cover
    I use Amsoil 0W-30 with the Amsoil 15k milage rated filter but change it every 10k
    Ericsopa likes this.
  16. Nov 10, 2018 at 4:22 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    getting ready to take my truck in for its first oil change and with that being said are you guys running synthetic or just regular oil?
  17. Nov 10, 2018 at 4:26 AM
    Synthetic
    T-Rex266 likes this.
  18. Nov 10, 2018 at 4:27 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Mobil 1 Extended Performance (full synthetic) 0W-20
    KnuckleHD and TXRailRoadBandit73 like this.
  19. Nov 10, 2018 at 4:27 AM
    Why not change yourself, easy to do save you some money, unless you have free oil changes
  20. Nov 10, 2018 at 4:36 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    it came with free oil changes otherwise i would
  21. Nov 10, 2018 at 4:37 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
  22. Nov 10, 2018 at 4:42 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    not sure what they offer at the dealership?
  23. Nov 10, 2018 at 4:44 AM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    Mine uses Valvoline.
  24. Nov 10, 2018 at 4:46 AM
    Should be Mobil1, ask em 1st
    netranger6 likes this.
  25. Nov 10, 2018 at 7:53 AM
    Blueknights75
    Ron
    Clayton, NC
    Full Synthetic as it came from the factory.
  26. Nov 10, 2018 at 5:35 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    0W20 oil is only available in synthetic.
  27. Nov 10, 2018 at 5:50 PM
    Ericsopa
    Ericsopa Old man and the sea
    Amsoil 0W20 synth.
  28. Nov 10, 2018 at 5:59 PM
    Rob371
    Rob371 New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    0-20 in the Auto Value (local parts chain) branded bottle. It's produced by Valvoline at roughly half the cost of the recommended Mobil 1.
  29. Nov 10, 2018 at 6:28 PM
    Rob371
    Rob371 New Member
    Rob
    2007 Tundra Crewmax
    That's not necessarily true.
    Some manufacturers, and even engine remanufacturers recommend break in on traditional oil with a zinc additive for the first two oil changes. Some recommend a blend of synthetic and traditional oil and a zinc additive for the first two oil changes. After that do what makes sense for your climate and intended usage.
    Main reason is higher oil consumption during break in with synthetic because the rings don't seat. I've heard of this on vehicles up to 10,000 miles before the oil consumption slowed or stopped.
    Maybe you know and trust your shop, and there are some excellent ones out there, but I've worked in and dealt with many shops and dealerships. I've seen lots of guys come and go in and out of this trade. You can't always rely on them following recommendations, even when you request a specific oil. Sometimes the requested info doesn't get passed along and often the guys doing oil changes are also newbies. I'm not saying everybody, but it occurs. 34 years in repair business so believe me on this one.
    gosolo[QUOTED] likes this.
  30. Nov 10, 2018 at 6:34 PM
    gosolo
    Ray
    NW Oregon
    Rob,
    That’s good information. I wonder if that’s why it seems like my truck was only getting broken in around 5000 to 8000 miles. I’m pretty sure that I’m not the only one starting and staying with synthetic.
    NewImprovedRon likes this.
