What kind of side rails?
Discussion in '3rd Gen Tundras (2014+)' started by crsides, Mar 14, 2019.
  1. Mar 14, 2019 at 6:11 PM
    crsides
    crsides [OP] New Member
    Just got a 2018 tundra 4x4 DC, SR5 with 18" wheels. The wife needs help getting into the cab. We are both 70+ and lost a little spring in the step. I see step side rails, running boards, and something called sliders. I thought the running boards would be easier to use, but a guy a the 4 wheeler shop said the rails hung lower and would be easier for her. Opinions please.
    Charlie
    jewsNbrews and Pinay like this.
  2. Mar 14, 2019 at 6:26 PM
    Pinay
    Pinay Ultimate Grand Supreme Member Staff Member
    Monet
    2015 Black - SR5 - CrewMax - 4x4 - TSS
    TTC #186
    Sliders are mainly for off-roading, protects the truck's undercarriage if your truck scrapes over rocks.
    You would probaly want to look into running boards, there are even ones that are mechanical, that slide down for you to step on when you open doors. How far down the steps would go depends on truck height and where you could step comfortably.
    Welcome to the forum Charlie!
    15whtrd, Mnorris1206 and Faht Nocker like this.
  3. Mar 14, 2019 at 6:35 PM
    Mnorris1206
    08 tundra
    Tyger makes some nice step bars but if you want a clean look. Look at Amp research steps .
    Welcome from Indiana.
    Pinay likes this.
  4. Mar 14, 2019 at 8:41 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    +1 for Amp Research
    Welcome from Sin City
    Pinay likes this.
  5. Mar 14, 2019 at 9:11 PM
    crsides
  6. Mar 14, 2019 at 9:51 PM
    Trooper2
    Trooper2 Premium Lone Star Member
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Hankook Dynapro ATs, N Fab 3 Hoop Nerf Bars, TRD Wheel Locks, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Welcome from TX! If keeping truck stock height those Westins should certainly help. There are many to choose from.
    There is also a grab handle you can add to the front pillars to help get in as well.
    Good Luck!
  7. Mar 14, 2019 at 10:01 PM
    phabej
    phabej New Member
    2018 White Tundra SR5 Sport CM 4x4
    I use these iboards, I looked them. This is the second truck I've installed them. Not too low or too high. Good grip you won't slip. I need them cause I have an infant helps getting into the rear.
    Pinay likes this.
  8. Mar 14, 2019 at 11:06 PM
    fishing guy
    fishing guy New Member
    Billy
    2017 White Platinum 4x4 Tundra
    N/A
    same as phabej. I tow a bow near salt water so just went with the cheap ones
    Pinay likes this.
  9. Mar 15, 2019 at 4:01 AM
    rival1
    rival1 New Member
    2016 trd off road crew max
    Leveled on 275/70/18
    I went with the tyger tube steps they work great very sturdy!
    Pinay likes this.
  10. Mar 15, 2019 at 9:00 AM
    crsides
    What are these?
  11. Mar 15, 2019 at 9:02 AM
    Mnorris1206
    08 tundra
  12. Mar 15, 2019 at 10:10 AM
    AggieTundra
    AggieTundra New Member
  13. Mar 15, 2019 at 10:16 AM
    crsides
    So, how do like them? Pros cons?
  14. Mar 15, 2019 at 10:23 AM
    Turk980
    Turk980 Freedom Isn't Free
    2019 Tundra Limited TRD Double cab
    Leveling kit, tires and wheels, fender flairs, nerf bar steps, flow master dual exhaust, spray in bed liner, rear airbags
    i have nfab on mine, really like them, planty of space to step on and i like the looks, they also help with keeping mud and snow off of the truck
    matrdguy and TXRailRoads73 like this.
  15. Mar 15, 2019 at 11:22 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    My advice would be to watch the local FaceBook Marketplace and Craig's List for a few days. A lot of guys buy a truck that already has steps on them and immediately replace them and sell the ones that came with the truck. Around here, you could buy the quasi- OEM ones with less than 1K miles for $100 twice a day for a week.
    TRDSPORT118 likes this.
  16. Mar 15, 2019 at 12:21 PM
    TRDSPORT118
    TRDSPORT118 New Member
    2018 Black TRD Sport
    I’ve also wanted some but I HATE the gap between the body and the rail. Plus DC options are limited. Idk why. The DC and crewmax sell about evenly.
  17. Mar 15, 2019 at 12:29 PM
    TRDSPORT118
    Where’s this?
  18. Mar 15, 2019 at 2:20 PM
    DaddyPete
    DaddyPete New Member
    Peter
    Birmingham, Alabama
    2016 Sky Metalic Silver Toyota Tundra SR5
    Installed Weather Tech Vent Shades Installed Weather Tech Rear Floor Liner Installed Husky X-Act Contour Front Floor Liners Had Havoc Offroad HS3 Black Hoop Steps installed by Sport Trucks of Birmingham Swapped out all Interior Lights, Brake Lights, Reverse Lights, Rear Turn Signals, Cargo Lights, 3rd Brake Light, Front Turn Signals, Parking Lights, Fog Lights and Headlights with LEDS from Headlight Revolution Installed a Pop & Lock® PL8535 - Power Tailgate Lock Installed OOOO Shit Handle on Drivers side. Parts from Toyota of Cool Springs Installed a Weather Tech Roll Up Pickup Truck Bed Cover Installed an UnderCover® SC400D - Single Lid Swing Case in the truck bed on Drivers side Installed Front and Rear TRD Sway Bars. Parts from Toyota of Cool Springs Installed a Stealth Mount LED Light Bar - Behind Grille from Headlight Revolution Installed a CUSTOM LED BACKLIT TUNDRA EMBLEM from Harmon Customs Had Factory Tint removed and had 30 % Tint installed by Sundown Tint to match the rest of the truck windows Had Tow Hooks Powder Coated by Coyote Coatings Installed Hood Grille Knight Rider NSV LED Light Bar Kit Installed a Ronin Factory 50 Cal Bullet Antenna Installed Bed Lights from Matt Gecko Got 4 New Shoes - General GRABBER HTS 60 275/65R18 116T from Southern Rubber Tire Swapped out factory Fog lights and installed Squadron Sport Amber WC from Baja Designs Installed Bed Mat from Toyota of Cool Springs Swapped out old Backlit Toyota Emblem for a new Custom Backlit Toyota Emblem from Harmon Customs Installed SDHQ Built A-Pillar Light Mounts Installed Squadron Pro Driving Combo LED set from Baja Designs Swapped out factory wheels for a set of Ray10 Matte Gunmetal 18x9 Wheels from SCS Performance Installed Tundra Bed Mat from Toyota of Cool Springs Installed 8" stainless steel system from Dirty Deeds Industries Installed Genesis Dual Battery System Installed 2 Odyssey 25 PC1400 Extreme Batteries Installed Power Aid Throttle Body Spacer Installed Distressed American Flag decals on both rear windows from Decal By Designs Installed Cup Holder/Shifter Trim Rings, Vent Rings and Climate Knobs from AJT Design Have a Micro-Start XP-l Jump Starter and Personal Power Supply
    I have Havoc Offroad HS3 Black Hoop Steps. My Mom is 80+ she has no problems getting into my truck. She also uses the handle to help get in as she steps up.
