What kind of connectors do you prefer?
Discussion in 'Lighting' started by fisherman951, Dec 12, 2017.
  1. Dec 12, 2017 at 10:47 AM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    So getting ready to add some lights and mods to the tundra but was wondering what ppl prefer to use for conectors.
    crimp butt connectors?
    Posi tap?
    T tap?
    Anything else?
  2. Dec 12, 2017 at 10:51 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    NewImprovedRon likes this.
  3. Dec 12, 2017 at 10:57 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    My preference is butt connectors with heat shrink adhesive.
  4. Dec 12, 2017 at 12:01 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Thanks guys
  5. Dec 12, 2017 at 12:59 PM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Depends on where the connection is made. Under hood, crimped butt connectors with heat shrink. Under dash, posi taps
  6. Dec 12, 2017 at 1:02 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    I solder and heat shrink every connection I do, no exceptions. But i'm an electronics tech by trade lol.
  7. Dec 12, 2017 at 1:46 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Same here. I solder and heat shrink. I also run everything in loom, sometimes split loom and sometimes braided.
  8. Dec 12, 2017 at 2:13 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, especially on trailer wires or anything outside of cabin.
  9. Dec 12, 2017 at 7:26 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    AxelsHumanDad likes this.
  10. Dec 12, 2017 at 8:47 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Everyone needs to copy this guy if it’s electrical related
    NewImprovedRon and 831Tun like this.
  11. Dec 13, 2017 at 4:38 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    :thumbsup:
    Picabond at work since it's inside slot machines, solder and shrink on my vehicles.
    831Tun and NewImprovedRon like this.
  12. Dec 13, 2017 at 4:39 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I know, but they don’t make em like they used to (old dudes or wire connectors)
  13. Dec 13, 2017 at 4:41 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I’m looking to get some battery terminals and need about 8 connections. Any recommendations?
  14. Dec 13, 2017 at 4:47 AM
    birdman076
    Chuck
    Montana
  15. Dec 13, 2017 at 4:49 AM
    Eclipsed & Floating
    Voluptuous Whitey
  16. Dec 13, 2017 at 4:51 AM
    birdman076
    Chuck
    Montana
    So a distribution block or you looking for like a bracket that mounts to the battery and repositions the terminal?
  17. Dec 13, 2017 at 4:51 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Bracket that mounts to the battery. Thanks for wording that properly for me
  18. Dec 13, 2017 at 4:57 AM
    Eclipsed & Floating
    Voluptuous Whitey
  19. Dec 13, 2017 at 4:57 AM
    birdman076
    Chuck
    Montana
    I know what you are talking about but can't for the life of me find one lol. Must be a terminology thing. My batter has one on it from the factory on the ground side. i guess at worse you could get some flat stock copper and bend one up yourself. At least you would have control over the shape and thickness at that point.
  20. Dec 13, 2017 at 4:57 AM
    Eclipsed & Floating
    Voluptuous Whitey
    http://gpcaraudio.com/gp-audio-sae-style-6-spot-machined-battery-terminals/
    birdman076[QUOTED] likes this.
  21. Dec 13, 2017 at 4:57 AM
    birdman076
    Chuck
    Montana
  22. Dec 13, 2017 at 4:58 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Just ordered a set
  23. Dec 13, 2017 at 7:17 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Me too and have been thinking about them ever since
    csuviper and NewImprovedRon like this.
  24. Dec 13, 2017 at 7:52 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No issues with them at all and they still look good.
  25. Dec 13, 2017 at 7:58 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Worriedman50 and NewImprovedRon like this.
  26. Dec 13, 2017 at 7:45 PM
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    831Tun[QUOTED] likes this.
  27. Dec 13, 2017 at 8:15 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Will do tomorrow.
    Worriedman50[QUOTED] likes this.
  28. Dec 15, 2017 at 5:16 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I'm in the process of installing an ARB compressor and 42" light bar so that's why the blk/blu loom is hanging loose. Light bar relay is aft of the new fuse box.2017-12-15 13.55.57.jpg
    The new fuse box helps keep the clutter down around the battery.2017-12-15 14.02.34.jpg
    I drilled +/- 1/8" holes to hang the loom with zip ties, to be cinched tight later.
  29. Dec 15, 2017 at 7:07 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Did you put a fuse between the new box and the battery?
  30. Dec 15, 2017 at 7:08 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No. It never occurred to me but might not be a bad idea.
