What is your preferred use for the cube lights on a rear bumper?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Beef, Sep 22, 2020.
  1. Sep 22, 2020 at 9:17 AM
    Beef
    Beef [OP] New Member
    2020 Tundra 4x4 TSS
    I'm trying to decide if I want to hook my 2020's RC rear bumper cube lights into my reverse lights to boost my backup view or tie them into say my bed/cargo lights so I can flip the switch and have them as needed. My hold back on the cargo tie in, is I don't have a boat anymore so I can't really think of a use where I need bumper LEDs behind my truck. I do use a 16' trailer at my deer lease but its more of a day time usage for toting water and feed. What do you folks prefer?
    DBLTRBL likes this.
  2. Sep 22, 2020 at 9:50 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
  3. Sep 22, 2020 at 10:03 AM
    Beef
    2020 Tundra 4x4 TSS
    I'm not quite that talented but I'm all ears if you have a link or video to get it accomplished.:D
  4. Sep 22, 2020 at 10:07 AM
    snivilous
    SW UT
    I'm no electrical engineer :D, but I think you'd just run from both switching devices to the LED with a diode. So if you're tapping into the switch, go to both the cargo switch and the reverse switch, or if you're going to the lights go to both lights, then have something like this: https://www.amazon.com/12v-one-way-diode/s?k=12v+one+way+diode inline, so the reverse lights wont turn the cargo on and vice versa. Bit more wiring though. And take that with a grain of salt, I had to look up what an electrical check valve is even called, but in my brain all that makes sense :D
  5. Sep 22, 2020 at 10:16 AM
    DBLTRBL
    DBLTRBL New Member
    Bill
    Iowa City
    2016 sr5 Crewmax TRD Off Road
    de-badged, hood decal, Pro Headlights, Paint Match Pro grill and hood. DVD monitors. neoprene seat covers, weathertech floorliners
    Did your bumper come with License plate lights?
  6. Sep 22, 2020 at 10:41 AM
    Beef
    2020 Tundra 4x4 TSS
    Yes it did. They are supposed to be used to mount the actual license plate but I went with standard license plate bolts and moved the lights just outside the plate so I don't have to disconnect/cut wires to replace a plate. See the black poles just outside the top corner of each plate.
  7. Sep 22, 2020 at 10:54 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    Yup, that could work. It’s called diode OR’ing. I almost did it for the aftermarket backup cam on my taco so that I could have anytime camera or have it auto turn on in reverse.
    snivilous[QUOTED] likes this.
