What is the stock wheel backspacing?
Discussion in 'Wheels & Tires' started by goffredo, Sep 27, 2018.
  1. Sep 27, 2018 at 9:35 AM
    goffredo
    goffredo [OP] Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Hey gang. Is there a reference somewhere? I couldn't find one. I'm trying to determine the backspacing of my stock wheels (without having to take the wheel off and actually look). I have a 2018 Limited with the 18" split 5-spoke TRD off-road package alloy wheels with the Michelin P275/65R18s.
    If I can't figure it out soon, I'll just jack the damned thing up and pop a tire off, and report back here.
  2. Sep 27, 2018 at 9:42 AM
    MikeyMTBs
    MikeyMTBs New Member
    +60
    15whtrd, Law323 and monaco730 like this.
  3. Sep 27, 2018 at 10:01 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    +60 is correct
  4. Sep 27, 2018 at 10:09 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    +50 for OEM Rock Warrior wheels, otherwise +60. There may be some OEM TSS wheels that are +50 also but I'm not sure.
    joonbug likes this.
  5. Sep 27, 2018 at 11:12 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Ron. Good info. I thought I'd read that somewhere.
    NewImprovedRon and joonbug like this.
  6. Sep 27, 2018 at 11:32 AM
    ToyotaTundraMike
    2015 Tundra
    Hmmm.
    Offset/backspace are two different things. One is measured in mm the other in inches.
    The way this guy asked the question makes it sound like he is looking at a lift that probably states “requires X amount of backspacing”.
    Offset won’t help him unless he knows the conversion formula.
    1/2 wheel width + offset (in inches) + 1/2” = backspace
    NewImprovedRon likes this.
  7. Sep 27, 2018 at 11:32 AM
    goffredo
    Wow thanks guys! I tried to convert offset to backspacing and I guess I need to know the wheel width as well, is it 8.5"? A few wheels have been mentioned already, so I'm specifically talking about 2018 Tundra LTD with TRD off-road package.
  8. Sep 27, 2018 at 11:33 AM
    ToyotaTundraMike
    2015 Tundra
    Pretty sure the stock wheels are 18x8. See above post for formula.
  9. Sep 27, 2018 at 11:36 AM
    goffredo
    Haha totally true. Well actually, I spoke to a guy at Icon who stated that a stock 2018 Tundra with stock TRD offroad package lift could accommodate 35" tires with a wheel that has a 8.5" width and a 5.75" backspacing. So what I'm really looking for is how far off from the stock spec such a wheel would be, just as a mental exercise more than anything else.
  10. Sep 27, 2018 at 5:33 PM
    ToyotaTundraMike
    2015 Tundra
    Probably easier to post your desired setup on here and let us help you out lol. 35”s typically require a cab mount chop for no rub from what I understand. If you are only going with 2-3” lift look into 295/70/18, they are a great size for our trucks, only slightly smaller than a 35. If your going with different rims try to stick around the +12 to +30 offset range for best fit with no rubbing.
