What in the world is this?
Discussion in 'Detailing' started by Terndrerrr, Feb 9, 2022.
  1. Feb 9, 2022 at 4:50 PM
    Terndrerrr
    Terndrerrr [OP] guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Went through a ton of mud and tight trails in rural Tennessee. It was very fun. I got some pinstriping from branches sticking out into the trail on the passenger side of the truck. While washing my truck today, this stuff came off. It seems like some kind of clear film. I was unaware that I had any kind of protective film anywhere on the truck, especially on the sides. This is halfway between the bottom of the door and the window. Right in the middle of the door. I don’t mind the pin stripes, but if this is going to get worse over time, I’d like to address it now.
    What is it, and how do I fix it? Thanks in advance.
  2. Feb 10, 2022 at 8:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    scraped the clear coat off?
    Saltyhero13 likes this.
  3. Feb 10, 2022 at 8:11 AM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Sure does look like clear never seen it do that though
  4. Feb 10, 2022 at 8:23 AM
    Terndrerrr
    Music City
    Dual 5.7s
    Yeah. It seems like the clear coat, but I’ve never seen it do that before either :notsure:
  5. Feb 10, 2022 at 8:29 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Any nasty chemicals possibly in that water that may have caused that?
  6. Feb 10, 2022 at 8:35 AM
    Terndrerrr
    Music City
    Dual 5.7s
    Just standard tap water out of the hose.
  7. Feb 10, 2022 at 8:53 AM
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    Either part of the tree or part of the truck. If it's part of the truck, then I would say it's the clear coat and the defect should be apparent when you look closely at that area, particularly when wet. Branches can impart oils, sap, etc onto contacted surfaces which may then dry as a film and could give that appearance as it peels off.
    Hopefully, it's the latter.
    Cg13055 likes this.
  8. Feb 10, 2022 at 8:58 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Looks like your truck is the victim of an MGM. Lucky you! Had it been a more sexy, more capable white one, the whole door would have been blown off!
    Darkness likes this.
  9. Feb 10, 2022 at 9:07 AM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    I’ve got a shit ton of pinstripes and have never seen that.
  10. Feb 16, 2022 at 8:27 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    We have rock guard in the bottom, maybe it was thicker clear and scraped off?
  11. Feb 16, 2022 at 8:28 AM
    Cg13055
    South Florida
    Good point, it can definitely be sap from a tree, if he pulled it off and there was no missing clear there would be no reason to say that it wasn’t part of a tree. Honestly it’s one of those things that unless it happens again don’t worry about it lol
  12. Feb 16, 2022 at 8:47 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That is Toyota tracking system. You have in your hand the transmission antenna, they are picking up signals to know if your driving is reckless so that they can void your warranty. They also listen in to hear you curse about not having a drivers side grab handle, a trans cooler, and having a bed that bounces like Shakira in a halftime show. Be glad you found it but delete the photo and any evidence before they see it!
  13. Feb 16, 2022 at 8:50 AM
    Cg13055
    South Florida
    For a second there you had me hooked.
  14. Feb 16, 2022 at 8:56 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The truth is out there...
    Cg13055[QUOTED] and Saltyhero13 like this.
  15. Feb 16, 2022 at 8:58 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Dental floss?
  16. Feb 16, 2022 at 9:18 AM
    Terndrerrr
    Music City
    Dual 5.7s
    Yes, that stuff is on the bottom of the doors. However, as stated in the OP, this is in the middle of the door, halfway between the bottom and the window, well above the rock guard.
    I’m leaning toward the sap theory. I’ve had other run-ins with sap, just never been pinstriped by a sappy branch that left a string of it on my truck. Still not sure yet though. Keeping an eye on it.
    Cg13055[QUOTED] likes this.
