What have you done to your 3rd gen Tundra today?
Discussion in '3rd Gen Tundras (2014+)' started by T-Rex266, Aug 10, 2014.
  1. Apr 14, 2019 at 7:25 PM
    Elfine
    Elfine New Member
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards
    Eglin Air Force Base in Florida.
    snarkscarbine and Jim LE 1301 like this.
  2. Apr 14, 2019 at 7:30 PM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    Whoa
    Elfine likes this.
  3. Apr 14, 2019 at 7:31 PM
    Jim LE 1301 Camaro Lover
    I thought that would be on a base.
    Elfine likes this.
  4. Apr 14, 2019 at 7:36 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I did a thing today. Wireless charge pad. I took step by step pictures too if anyone decides to copy and needs help. I'll load them to my build thread if people are interested. Looks OEM to me. I might even dress it up a bit with the red/black tuffskinz I removed from that area. Least that was an idea I came up with when I removed it. Time will tell if I ever get around to that 1 if I think I can make it work.
    Here's a little closer view of it. Install wasn't too bad.
    With all that black and red I got going on in the interior I felt the need to put some eye candy under the hood to match. Got a great deal on a used but looks new trd cai to match from a fellow member. I never would've bought 1 new and have been silently looking for a loooooong time. Finally got what I was looking for. I'll try to get that in not long after I get it later in the week.
  5. Apr 14, 2019 at 7:47 PM
    mgm16trdpro
    Northern NJ
    Hey now we gotta get together and do a double install day. If u haven't done it yet we can install the pop n lock and trd cai on both our trucks 1 day. My cai should be here within the week and I still gotta get the pop n lock. I got Amazon prime so when we come up with a day that works for both of us I just need least 2 days in advance to place my order. In the meantime I'm keeping my eyes open to find 1 cheap secondhand, like the cai.
  6. Apr 14, 2019 at 8:06 PM
    Okay.
  7. Apr 14, 2019 at 8:16 PM
    SiberianTundra
    SiberianTundra New Member
    Greg
    F-86 ?
  8. Apr 14, 2019 at 8:27 PM
    snarkscarbine
    Alex
    Dallas
    Looks like an A4.
  9. Apr 14, 2019 at 8:32 PM
    Chafe
    Chafe New Member
    Tucson
    2014 Silver Tundra SR5
    A-4
    F-86 did not have side intakes.
    SiberianTundra and snarkscarbine like this.
  10. Apr 14, 2019 at 8:41 PM
    DarthMurdicide
    DarthMurdicide Executive Redneck
    South Carolina
    This was a pretty labor-intensive weekend for ME...took about 8 hours for these two projects combined. It would probably only take a couple of hours for you modding pros! :rofl:
    The first project was installing color matched mirror caps and door handles. This was the "piece of cake"...a little under 30 minutes.
    The second project was no "piece of cake" for me...it was a couple of damn bakeries!! Inspired by all these puddle / running board lighting installs, I decided to put some LEDs under my running board. While I was running the wiring, I figured since I plan on getting a better suspension in the future for off-roading, why not go ahead and install rock lighting. Regarding the 7.5 hours it took me, in my defense, I wanted everything to be as close to waterproof as possible, so I used waterproof solder splice connectors on all of my wiring connections, which took some time. I also sheathed all of the wiring, and used wire-looms where the wire connections were. I used LOTS of zip ties as well to keep the wiring as high up underneath the truck as possible. I tied all of the lighting into the cargo light switch. Here are the pics, and hopefully some notes you might find helpful.
    Here are pics of the mounting points. Each running board has two LED pods, and I put a pod under each wheel well, for a total of 8 LED pods.
    I removed the factory POS JBL sub and installed my own. When you remove the sub, there is a bracket that comes out with it that bolts to the floor, which leaves you with a bolt and hole with no use. So that gave me a nice hole to bring the wiring through. I installed a rubber grommet in the hole to bring the wire through, so the wire doesn't rub against bare metal. I ran the wire to the wiring channel under the rear driver side door sill, found the darker pink wire, and tapped it. For the ground, remember that leftover bolt from the sub bracket? It fits perfectly into a threaded hole in the wiring channel which seems to serve no purpose. Ground found!! Finally, I wanted to cover up the hole where the wire comes through, so I found these Velcro circles, and it covered it up nicely. End results on the bottom. I can't get over how bright these little pods are! And the eight combined only pull 6 amps.
    Nebz, GAknight, WAtundra4x4 and 7 others like this.
  11. Apr 14, 2019 at 8:47 PM
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, DAP tuned (4-5-19),
    Throttle body service:
  12. Apr 14, 2019 at 10:30 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Smyrna, TN
    2019 White TRD Pro
    Yes they rubbed on factory suspension. Since that update I upsized my wheels to 35s and added shackles, coil shim, and bumper ships from coach builders pro set and still have some rub at full reverse lock. I tried to heat gun my flaps but it was a little cold today and didn’t work as easily as I thought gonna give it another go tomorrow
  13. Apr 14, 2019 at 10:34 PM
    escuzi_me
    William
    Smyrna, TN
    2019 White TRD Pro
    This is awesome and thx for the walkthrough. Might have to this one
    DarthMurdicide and Major like this.
  14. Apr 14, 2019 at 10:49 PM
    YTThao530
    YTThao530 New Member
  15. Apr 15, 2019 at 4:18 AM
    DarthMurdicide
    South Carolina
  16. Apr 15, 2019 at 9:44 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I fly into Eglin Air Force Base quite a bit when we go to Destin for vacation every other year!
  17. Apr 15, 2019 at 10:23 AM
    NAFlash
    NAFlash New Member
    Randy
    Tundra TRD Sport 4x4
    TA 4, Skyhawk. Navy used them as advanced trainers.
    Deafmate likes this.
  18. Apr 15, 2019 at 12:42 PM
    16TRD
    16TRD New Member
    2016 White crewmax
    Bite the bullet and order the vled v6 triton.
    ARamirez73 and escuzi_me like this.
  19. Apr 15, 2019 at 1:40 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country leveling kit
    Looks good. So do your lights come on when you unlock your truck?
  20. Apr 15, 2019 at 2:15 PM
    dochanson
    dochanson New Member
    Gabe
    Operation “No-Mo-Chrome” has begun. Grill/bulge and mirror caps have been ordered. I couldn’t pass them up since they were on sale.
    I decided to just paint the bumper caps. I had enough primer and clear left over from a motorcycle project. A 1/2 pint of the Barcelona red was $59! Seems like a lot.
    Super windy day down here in Corpus, so I’ll have some trash to sand out but overall they turned out great. I will reassemble tomorrow and continue anxiously waiting on my big box from Roman. 7D851881-FC89-45A7-97C2-552D65738B39.jpg821855D3-789B-4F76-B1D6-71695D2C4953.jpgC916D5DA-1D1D-46EE-80CD-B170B638155D.jpg
  21. Apr 15, 2019 at 2:22 PM
    MOT3L6
    MOT3L6 New Member
    Dustin
    Nebraska
    2015 CM Inferno TRD PRO
    Truck Covers USA American Roll Cover with Yakima Tracks, Nestah Firestick Antenna, Husky Liners X-Act, iHacker harness, 2019 TRD PRO LED Headlights, BD Squadron Fog lights-amber wc
    Swamp Phase...RLTW
  22. Apr 15, 2019 at 2:35 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio
    How much to do some stuff in MGM?
    Good looking work though!
    Major likes this.
  23. Apr 15, 2019 at 2:43 PM
    dochanson
    Gabe
    Thanks man. It’s strictly a hobby for me. I can’t imagine a shop charging more than a couple hundred, but that’s a total guess
  24. Apr 15, 2019 at 2:54 PM
    markg
    markg New Member
    NC
    2018 Tundra CM 1794 Edition
    Grab Bar, Running Boards,
    Gave it a bath and sprayed the wheel wells with tire foam, Cleans them up real nice
    JoshuaA, Ostrich, NAFlash and 4 others like this.
  25. Apr 15, 2019 at 3:32 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    3" level kit, Icon shocks, rear bags S&B CAI, anytime fog lights, LEDs, and...list growing.
    Did you do any other porting, or just polishing/ clean up?
  26. Apr 15, 2019 at 3:36 PM
    DarthMurdicide
    South Carolina
    Yes they do, tied into the cargo light and its on/door/off switch.
  27. Apr 15, 2019 at 3:53 PM
    DCB500
    DCB500 New Member
    David
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts
    Magnaflow dual exhaust finally completed!
    TundraMash, Ostrich, NAFlash and 5 others like this.
  28. Apr 15, 2019 at 3:58 PM
    Major
    Major TTC #0181
    Josh
    Winterfell, Westeros
    2017 CM Attitude Black Platinum
    Stock.
    Which one? How is it coated? Nice work!!
  29. Apr 15, 2019 at 4:24 PM
    Danbizzle2009
    Danbizzle2009 New Member
    MAINE
    2016 DC Tundra SR5
  30. Apr 15, 2019 at 4:26 PM
    Danbizzle2009
    MAINE
    2016 DC Tundra SR5
    How did you get the paint to stick to that smooth chrome?
